VPI/VCI or VID Number
geffers
Folks, exploring an option for a different connection method I note that when auto setup is selected the connection details show an entry for VPI/VCI or VID of 101
If I were to use a manual system of connecting to PPPoE is this an entry I would have to use?
Currently using a TP-Link modem/router TD-W9970
Geffers
2 REPLIES 2
Fixes: 395
Re: VPI/VCI or VID Number
As you're on Fibre you will need VLAN ID set to 101.
geffers
Cheers MisterW
Geoff
