VPI/VCI or VID Number
- VPI/VCI or VID Number
27-04-2021 7:52 AM
Folks, exploring an option for a different connection method I note that when auto setup is selected the connection details show an entry for VPI/VCI or VID of 101
If I were to use a manual system of connecting to PPPoE is this an entry I would have to use?
Currently using a TP-Link modem/router TD-W9970
Geffers
Re: VPI/VCI or VID Number
27-04-2021 9:00 AM
As you're on Fibre you will need VLAN ID set to 101.
27-04-2021 3:10 PM
Cheers MisterW
Geoff
