Hi all,
I happened to notice earlier today that my modem was synced at 73,999kb/s rather than its usual 79,997 (it claims headroom to above 83,000 usually, and still is at the moment). I rebooted it to see if it would sync at full speed again, and it didn't — again exactly 73,999.
Has my line somehow had its cap reduced from 80,000? If so, how to I get it back up? (And, just for interest's sake, why might this have happened? The line has been rock solid as far as I'm aware, and still has a bit of headroom both upstream and downstream when sunc at the 80/20 limits).
Modem stats included below (it's a DrayTek 2760) in case of interest / useful for diagnosis!
Thanks for any insights (I'll probably call support tomorrow in any case if it resyncs again at 73,999 when I reboot it at some point during the morning!) …
ATU-R Information |
Type: |
VDSL2 |
Hardware: |
Annex A |
Firmware: |
05-07-06-0D-01-07 |
Power Mngt Mode: |
DSL_G997_PMS_L0 |
Line State: |
SHOWTIME |
Running Mode: |
17A |
Vendor ID: |
fe004452 41590000 |
ATU-C Information |
Vendor ID: |
b5004244 434da4a1 [BDCM] |
Line Statistics |
Downstream |
Upstream |
Actual Rate |
73999 |
Kbps |
19999 |
Kbps |
Attainable Rate |
83449 |
Kbps |
25234 |
Kbps |
Path Mode |
Fast |
Fast |
Interleave Depth |
1 |
1 |
Actual PSD |
6. 7 |
dB |
13. 9 |
dB |
Near End |
Far End |
Trellis |
ON |
ON |
Bitswap |
ON |
ON |
ReTx |
0 |
1 |
SNR Margin |
8 |
dB |
15 |
dB |
Attenuation |
14 |
dB |
18 |
dB |
CRC |
0 |
7087 |
FECS |
0 |
s |
72969 |
s |
ES |
0 |
s |
909 |
s |
SES |
0 |
s |
149 |
s |
LOSS |
0 |
s |
0 |
s |
UAS |
30 |
s |
2111 |
s |
HEC Errors |
0 |
0 |
RS Corrections |
0 |
0 |
LOS Failure |
0 |
0 |
LOF Failure |
0 |
0 |
LPR Failure |
0 |
0 |
NCD Failure |
0 |
0 |
LCD Failure |
0 |
0 |
NFEC |
254 |
32 |
RFEC |
16 |
16 |
LYSMB |
5374 |
16 |
