Usually always 55mb down to around 900kbs currently
- Usually always 55mb down to around 900kbs currentl...
04-05-2019 10:12 AM
I've been with Plusnet for 5+ years and never once had any issues with my line - the service provided is usually perfect.
Over the last 10 days I've been getting very slow speeds on downloads and streaming services. My router is saying I'm connected at 55mb but I'm getting around 900kbs on all downloads. At first I thought my service was being throttled but read that's not something Plusnet do for heavy usage.
Could someone take a look at the line and see what's happening?
Thanks,
Re: Usually always 55mb down to around 900kbs currently
04-05-2019 11:46 AM - edited 04-05-2019 11:47 AM
Hi @tomplums,
I'm sorry that your speed has dropped and for any inconvenience that this is causing you.
I've tested your line and the test hasn't picked up the cause of the problem from here but the "parameters" section is unusual:
GEA Test Detail | |||
Circuit ID | NA | Service ID | BBEUXXXXXXXXX |
Test Outcome | Pass | ||||
Test Outcome Code | GTC_FTTC_SERVICE_0000 | ||||
Description | GEA service test completed and no fault found . | ||||
Main Fault Location | OK | ||||
Sync Status | In Sync | ||||
Downstream Speed | 54.9 Mbps | ||||
Upstream Speed | 10.0 Mbps | ||||
Appointment Required | N | ||||
Fault Report Advised | N | ||||
NTE Power Status | PowerOn | ||||
Voice Line Test Result | Pass | ||||
Bridge Tap | Not Detected | ||||
Radio Frequency Ingress | Not Detected | ||||
Repetitive Electrical Impulse Noise | Not Detected | ||||
Cross Talk | Not Detected | ||||
Downstream Policing Discard Rate | 0.0 | ||||
Customer Traffic Level | Upstream and Downstream Traffic Detected | ||||
Technology | VDSL |
Parameters | MIN | MAX | AVG |
Down Stream Line Rate | -1 Mbps | -1 Mbps | -1 Mbps |
Up Stream Line Rate | -1 Mbps | -1 Mbps | -1 Mbps |
Up Time | -1 Sec | -1 Sec | -1 Sec |
Retrains | -1 | -1 | -1 |
Current and Last 15 Minute Bin Performance | ||
Parameters | Last Traffic Count(Upto 15 mins) | Current Traffic Count(Upto 15 mins) |
Start Time Stamp | 2019-05-04T10:12:19Z | 2019-05-04T10:27:19Z |
Ingress Code Violation | 0 | 0 |
Egress Code Violation | 0 | 0 |
Errored Seconds | 0 | 0 |
Severely Errored Seconds | 0 | 0 |
Unavailable Seconds | 0 | 0 |
Does the speed issue solely affect wireless connections or are wired connections affected too? Please can you run through our troubleshooting guides here and let us know how you get on.
