Using the Hub One router with unlimited broadband (ADSL2+)
FIXED- Subscribe to RSS Feed
- Using the Hub One router with unlimited broadband ...
23-11-2018 2:26 PM
Hello everyone,
I ordered the upgrade from regular Unlimited Broadband to Unlimited Fibre Extra the 20th November and the new Hub One arrived in impressive 2 days and now it is sitting there gathering dust.
I read it also have a ADSL2+ modem so I was wondering if I can replace my Thomson tg582n with the new Hub One, this way I can start using 5Ghz WiFi and setting up the ports (I have a bit of a mess in my network)
If I can start using it it, what should I do when I receive the activation confirmation of my new service? probably just turn it off and on again so it connects to the VDSL, right?
Thanks,
Jose
Fixed! Go to the fix.
23-11-2018 2:42 PM - edited 23-11-2018 2:44 PM
The Hub One with work fine on your current ADSL2 & should just reconfigure itself when your FTTC goes live
you should need to do nothing, although you may have a slower that you expect first day on FFTC (as Plusnet may not update the profile until close to midnight on the 'go live' day)
The ADSL wil drop while they connect the copper to the fibre cabinet, so the Hub One will lose service & should simply reconnect to VDSL when this is done
At least that was my experience when I upgraded 2 years ago
