Using an openreach modem decreases speed
NorthEasterner
I fished out an old Huawei 3B Openreach modem and hooked it up and connected etc..
Ran a speedtest before hooking up the openreach modem and my hub one was syncing at 55mb on speedtest.net and BT wholesale and upload of 13mb.
Once using the modem, my download speed decreased to 47mb BUT my upload increased to 14mb Shocked
Anyone know why this is?
I'll give it a week on the modem and if no improvements I'll revert to the original set up.
Ex Plusnet Fibre customer. BT Infinity Customer using a BT Smart Hub. If you wish to say thanks, please click the thumbs up Thumbs Up
ray_dorset
Re: Using an openreach modem decreases speed
Have you got any stats from the HG612?
NorthEasterner
Unfortunately not.
It is an unlocked HG612 but I cannot access the UI despite changing computer IP to 192.168.1.100 etc.
NE
ray_dorset
Probably best to unlock it again as without stats it would just be a guess
bugs4me
There does seem to be a problem with the BTOR modem throttling speeds but it's not an exact science - oh if only. I ditched the BTOR modem and went for the all in one Billion 8800NL. The Broadcom chipset of the Billion works fine on my antiquated copper wiring.
But and it is a big BUT, it's all a hit and miss situation in my experience.
NorthEasterner
I've tried to but no success.
Might be the case, I gave up using the BTOR modem and went back to the all-in-one set up after a few complaints this evening! Crazy3
NE
ray_dorset
Oh I know what you mean about unlocking. I have one PC that does the unlock no trouble but my main PC won't even recognise that the reset button has been held in since power-on. I'm sure it's something to do with Ghostery or windows defender but ... !?!
NorthEasterner
Will try on the Mac in the morning.
NE
