Using airport express as an extender
- Re: Using airport express as an extender
09-07-2015 7:37 AM
Hi all
I'm new to Plusnet and really happy with both the service (after a year of hell with TalkTalk...) and speed of connection. However, I use airport express routers to extend my network and stream music / network printers and I cannot setup the express as an extender. No problem to get it to join the network but as soon as I then try to reconfig as an extender it doesn't find an internet connection.
Is this because the standard Technicolor router is incompatible or something I (being inept) am not doing?
Help and suggestions most gratefully received.
Many thanks
Many thanks
Message 1 of 6
(2,123 Views)
5 REPLIES 5
09-07-2015 8:45 AM
I've got an airport extreme plugged into the technicolor one OK.
have you set it to bridge mode?
Message 2 of 6
(1,744 Views)
09-07-2015 12:19 PM
Hi Dvorak, thanks for response. I was attempting to extend it wirelessly - i.e. have the airport in another room, pick up the signal and extend it rather than hard wire it into the router as I won't then gain any additional coverage...
adie:quote
adie:quote
Message 3 of 6
(1,744 Views)
09-07-2015 12:26 PM
ok, I haven't tried that - there's an article here if you've not already seen it https://support.apple.com/en-gb/HT202056
Message 4 of 6
(1,744 Views)
09-07-2015 4:21 PM
Thanks, have had a read through it and it all refers to Mac only products. It does mention WDS and I wonder whether the Plusnet router is WDS capable - perhaps this is the problem. Having looked at comments on Mac sites also people seem to be plugging straight in and using maybe an Extreme as their primary router and then extending with Express...... ho hum!
Message 5 of 6
(1,744 Views)
09-07-2015 6:22 PM
I think the page dvorak linked you to does give the right information, along with the instructions it links to https://support.apple.com/en-gb/HT202076 - you want to follow the instructions to set the Airport Express(es) in a Wireless Distribution System (WDS), but where you assume that your Technicolor router is the main base station and is already configured correctly. Apple's Airport Utility program is available for Windows: https://support.apple.com/kb/DL1547?locale=en_US
Message 6 of 6
(1,744 Views)
