Using Own Router
Using Own Router
I am currently using the plusnet one router and the WiFi signal is damn awful compared to my old netgear. I was going to upgrade and buy myself a secondhand netgear router or another make from fleebay. Can anyone recommend a make or model that they are using. Any help or advice would be great
Moderator's note by Dick (Strat): All caps title/text edited as per Forum rules.
1 REPLY 1
Fixes: 11
Re: Using Own Router
Have a look here on previous thread May help you
https://community.plus.net/t5/My-Router/Best-Non-Plusnet-Router/m-p/1366197
