Using Nighthawk VDSL modem router with FTTC service
- Using Nighthawk VDSL modem router with FTTC servic...
Sunday
Hi
I am using a Netgear Nighthawk AC2600 VDSL/ADSL modem router on basic Plunet service at the moement. I have requested an ugrade to their FTTC service - due shortly and have receieved their Hub One Modem Router
I want to use my current Netgear equipment but I am confused - the netgear setup asks me to use the internet user name and password, is this the wireless network name and password key one on the back of the Hub One router I have been sent?
Re: Using Nighthawk VDSL modem router with FTTC service
Sunday
No. Your user name is your Plusnet account name followed by @plusdsl.net. Your password is your account password. Full settings are here. https://www.plus.net/help/broadband/broadband-connection-settings/
Sunday - last edited Sunday
Hi @RR2
Welcome to the forum.
It is neither of those, fortunately the internet user name is the same for ADSL and VDSL so in theory you need to do nothing after the switch over as once once the line connection recovers it will attempt a login using the same credentials.. In some case it maybe necessary to power cycle the modem and router.
The internet username is in the format username@plusdsl.net the username and password are the same as used for the members centre excluding the @plusdsl.net
Hope this helps
Dan.
I need to type faster !
@Dan_the_Van might be right and it reconfigures automatically but if you look at the attechment in my previous email you will note that PPPoA has to change to PPPoE and you may need to set the VLAN up.
If you have a Hub One running on ADSL then this WILL reconfigure automatically.
Sunday
Hi both you guys - thanks
I am currently using the NightHawk (not the Hub One - still in the box) and expect to be upgraded in say 10 days
From what you have said there is a good chance that there will be no changes necessary (the Netgaer video says my gateway will automatically detect my connection and the ask for my username and password) which I now know is my member centre name and password
Have I got it right,?
If so fingers crossed and I will let you know
If I hit problems I assume I can come back to this forum?
Sorry I am new to this
Sunday
Nearly, don’t forget to add @plusdsl.net to your user name.
Don’t hesitate to come back if you have a problem.
Sunday
Just keep your Hub One as a spare, they fetch next to nothing on Ebay.
Your NightHawk is quality kit and will probably carry on connecting at the higher speed without any changes.
Any problems and there are no shortage of experts here to help you.
