Use of standard routers with FTTC
- Re: Use of standard routers with FTTC
28-03-2016 12:00 PM
This has probably been asked before but if the fibre only goes to the cabinet not the home can I still use my Cisco router (x2000) as I'm a tightwad and don't want to have to spend out on a new fibre compatible router.
Many thanks.
Many thanks.
Message 1 of 5
(902 Views)
4 REPLIES 4
28-03-2016 12:03 PM
Message 2 of 5
(683 Views)
28-03-2016 12:25 PM
Even if the fibre only comes to the cabinet. Is it an encapsulation problem?
Message 3 of 5
(683 Views)
28-03-2016 12:35 PM
Message 4 of 5
(683 Views)
28-03-2016 12:42 PM
Is this what you've got ? - http://www.linksys.com/tr/support-product?pid=01t80000003K7dgAAC ?
If so, it appears to be an ADSL2+ router, BUT also has a "CABLE" WAN socket !,
therefore you could buy a cheap FTTC modem from eBay (for about £20) and plug that into the "CABLE" port on your router.
Message 5 of 5
(683 Views)
