Usage report
aks100
Usage report
I logged in to my Plusnet HubOne and it reports excessive transmitted data that I cannot explain:
Connection time: 21 days, 00:02:29
Data Transmitted/Received: 51.1 GB / 156.9 GB
I have no sharing apps (that I know of). Download, with iPlayer, etc make sense. Any suggestions how I find out what is causing this?
I previously would have looked at the usage stats page in Plusnet My Account, but that no longer seems to be available.
4 REPLIES 4
Fixes: 418
Re: Usage report
@aks100
It records data since the last factory reset, not the connection time. So this could be a total of several years data, not 3 weeks worth.
aks100
Re: Usage report
Thanks, it's still a bit of an odd ratio, I mean, I use iPlayer, YouTube, etc all the time, practically never upload anything, so that seems strange to me.
As you mentioned in my 'clear evbent log' thread, I hope that a reset will clear this too.
adam945
Fixes: 113
Re: Usage report
We wouldn't be able to see what apps / categories are using your data to be honest @aks100
Let us know how you get on with the Factory Reset. Smiley
 Adam
 Plusnet Help Team - Leeds
aks100
Re: Usage report
I cleared the box (reset pin) and monitored for a day:
Connection time: 0 days, 19:12:32
Data Transmitted/Received: 191.9 MB / 7.1 GB
Seems more in line with my expectations.
Of course, working from home more often, using video calls to reach family members too, all contributes to a very different usage pattern. I'll continue to monitor and report back if I detect anything suspicious.
