Usage Monitor
daz1107
Usage Monitor
Anyone else have a broadband usage monitor which shows zero for the last couple of days?
I was streaming programs all day yesterday but no usage.
It doesn't really matter as I'm on unlimited, but this is the third time it's happened recently.
Fixes: 71
Re: Usage Monitor
If you disconnect from Plusnet using the router GUI, wait 30 seconds then reconnect it's possible that your usage will start to show again..
David
Fixes: 167
Re: Usage Monitor
Spraxyt is right, just try dropping the connection briefly and usage should start coming through in an hour or so.
 Chris Parr
 Plusnet Staff
daz1107
Re: Usage Monitor
Thanks for the reply - i'll give it a go!
