Urgent Can Somebody from PlusNet contact me regarding possible DNS problems
pg1
Until the end of October 2016 I have regularly been receiving 70-75Mbps download from my PlusNet fibre connection.
Since then I have had to reboot my Openreach fibre router and my TPLINK  router connection to my pc on a daily basis to achieve any kind of internet connection.
I normally use Firefox as my default browser but the problem is consistent using any browser  i.e. Edge, Chrome or IE11
My current download speed varies between 10 & 20mbps I am constantly getting the error “problem loading page” when try to load pages in new tabs.
From a cmd prompt I cannot ping google by name and most times not by IP address either
Which suggests to me some kind of DNS error? I have tried using the alternative IP’s on IP4v of 208.67.222.222 & 208.67.220.220 with little success.
I am using the following hardware
Model:- Echolife HG612
Firmware ver V100R001C01B028SP10
 This is connected by Ethernet cable to a
 TPlink Ultimate Wireless N Gigabit Router
 Model:- TL-WR1043ND
 This is connected by Ethernet cable to my PC Network adapter
 Realtek PCIe GBE Family Router
Driver ver 9.001.0404.2015
 I am running 64 bit Windows10 on an Intel(R) Core(TM)2  Quad CPU Q8300 @ 2.50 GHz
 I could really do with some help from PlusNet on this issue. I have tried to use their online chat facility but its invariably off line!
Plusnet Staff
Plusnet Staff
Fixes: 116
Re: Urgent Can Somebody from PlusNet contact me regarding possible DNS problems
Hello there,
I'm aware of a current data transfer issue with Windows 10 PCs. The fix has been to manually setting your IP address in the network adapter IPv4 properties. For example, assuming the default gateway of your TP link router is 192.168.1.1 you could manually assign your IP to 192.168.1.20.
Then, manually assign your DNS server address to
Preferred DNS Server: 212.159.6.9
Alternate DNS Server: 212.159.6.10
I hope this helps
From when I joined the Plusnet Help Team in May 2017 my main Community account is @Gandalf.
 Plusnet Staff
Fixes: 31
If you suspect a DNS problem, have you tried changing the DNS options in your router to use Google 8.8.8.8 and 8.8.4.4 ?
MJN
Pinging by IP address don't use DNS at all so that particular issue suggests a different cause.
MJN
Do you have another device (PC, phone etc) that you could be used to help determine whether it is indeed your connection or perhaps just that one machine at fault?
