Upstream issues?
Stevef1
Upstream issues?
Hi Plusnet, yes I'm still here.
To be totally honest my connection has been 'okay' for the past few weeks, so why move if it's okay? Smiley
Anyway to get to the issue, could you please check my upstream?  I seem to have an issue with it, for example using 'facetime' I can get incoming calls fine, but outgoing ones rarely work, we have done tests and its only like 1 in every 4-5 calls actually connect when calling out, but 5/5 work when it's incoming.  That along with other issues leads me to believe the problem is my upstream.
Thank you
3 REPLIES 3
adamwalker
Fixes: 221
Re: Upstream issues?
Hey,
I've just been running some diagnostic checks and no problems to do with your upstream are being flagged up.
What are the results of a speed test showing you?
Adam
 Adam Walker
Stevef1
its averaging around 1.2-1.4mbps
I have come to the conclusion that my upstream is just too low , so I need to possibly look at how much it will cost to have you upgrade it for me.
I'm currently 'out of contract' and I would consider upgrading my account to get faster upstream, however I'm not willing to take an 18 month contract just to upgrade my account.  What are my options?
Chris
Legend
Fixes: 169
Hi there ,
Our customer options team would be best placed to discuss this with you, they can advise on what contract lengths and deals would be available to you. They can be reached on 0800 013 2632
