Upload speeds on Unlimited Fibre Extra
r4w
Hello,
I have tried to contact you by chat (I can't stand to wait 15 minutes or more by phone) but it's two days that the chat is unavailable.
I'm a new customer with Unlimited Fibre Extra and I switched from BT Infinity 1.
First of all, I still don't understand why it took almost 5 hours to switch the broadband from when I have received the first email that you have switched my phone line.
My secondo concern is that the download/upload speed profile seems to be unchanged and it's now over 24 hours that the change happened.
I'm not expecting a big change in the download speed (even if I have seen better speeds earlier with BT), but 5 Mbps is a very poor upload speed and half of the estimate low bracket on your website.
Could you please check and let me know?
Thanks.
19 REPLIES 19
rongtw
Fixes: 12
Re: Upload speeds on Unlimited Fibre Extra
Hi , unfortunately the Chat has been turned off Angry by Plusnet to allow more staff on the phone lines .
Hopefully one the the forum staff will see this and check your profile , it may have not been set correctly Thumbs_Up
You could try to reboot your router as it may help Smiley
r4w
Hi rongtw, I have read after posting about the chat, I can't really wait too much time at the phone while at work.
I have tried to restart the router a couple of times but no joy (not today to be honest).
I would prefer to have confirmation I'm on the right profile first Smiley
r4w
Just tried a restart:
Line state: Connected
Connection time: 0 days, 00:19:49
Downstream: 43 Mbps
Upstream: 5.38 Mbps
rongtw
Fixes: 12
hopefully @Gandalf can help
r4w
I have just raised a fault in the end as nobody contacted me.
MatthewWheeler
Fixes: 479
Apologies for the delayed response.
I've checked and you've definitely been moved onto the 80/20 service but you may have a fault as the sync speeds are lower then expected.
We'll get that picked up as soon as possible.
 Matthew Wheeler
r4w
Thank Matthew, could you please let me know how can I check the fault that I have raised earlier? I can't find it in the portal, I would appreciate if you can provide me directions on the menu. Thanks!
Terranova667
Fixes: 5
Hi you should be able to find your open Ticket here, https://portal.plus.net/wizard/index.html
you will need to enter your Account user name and password.  Might be worth bookmarking it in your browser for future Use.
r4w
Thank you Terranova667, that was it! I didn't expect to see a fault as a question so I didn't check that out Smiley
r4w
Hi @MatthewWheeler, I have noticed that my line is going up and down a lot now, I understand that you're testing my line however I would like to check with you if you have any updates for me and when the tests are going to end. I have also updated the fault with this information.
Thank you!
Fixes: 1,600
The drop outs aren't caused by our testing.
I'll reply to your fault ticket in a mo
r4w
Thank you @Gandalf for the information.
I have updated the fault with some more tests.
In particular, I have reached out the connector underneath the Openreach MK3 socket and applied the filter included with the Plusnet One Hub, unfortunately the sync speeds are almost the same 😐
BT wholesale speed test shows:
Upload: 4.08
Ping: 50
I really hope we can get this fixed as soon as possible.
Thank you all.
Mustrum
Fixes: 77
Have you done a quiet line test with a corded phone? More info on the help pages.
r4w
I don't really use the phone, so I don't have one right now to make a test. I need to see if I have an old corded phone somewhere but I'm unsure how reliable it would be.
I'll try to see if I can make that test too, thanks!
