Upload speeds for packages
Bobalicious
I'm considering moving from copper to fibre in order to improve my upload speeds, but I can't seem to find details on the speeds in the package listings.
Can anyone let me know what the upload speeds are for each of the packages?
Fixes: 62
Re: Upload speeds for packages
up to 2Mb/s for normal and up  to 20Mb/s for extra
rongtw
Fixes: 12
Yes , it has been mentioned plenty of times before  that the Upload speed needs to be more prominent .
On the home page its slightly hidden in the Legal bit at bottom of the page , and of course they do tell you after you start the sign up process Sad
But you will see not a lot of ISP advertise the mini upload speed , its embarrassing
Fixes: 167
Hi @Bobalicious
As Oldjim advises, the upload speeds on our Fibre packages are up to 1.9Mb/s or up to 19Mb/s (depending on the line estimates and package taken).
 Chris Parr
 Plusnet Staff
