Upload speed reduction - Stay with current product
- Upload speed reduction - Stay with current product
04-07-2016 11:09 AM
I understand that my broadband is going to be 'upgraded' by reducing the upload speed available? If this is correct how can I opt out of this upgrade.
Upload speed is more important to me than download and I do not wand my upload reduced. What options do I have?
Re: Upload speed reduction - Stay with current product
04-07-2016 11:18 AM
Assuming that you are already achieving better than 10Mb/s upload speed then the only option is Fibre Extra (80/20)
If you aren't then going from 40/20 to 55/10 won't have any effect
04-07-2016 11:25 AM
I'm afraid it's not an optional chance, as Oldjim states the way to keep the higher upload (assuming you're getting more than 10Mb/s at the moment) is to move to the Fibre Extra Product.
04-07-2016 1:17 PM
So how do i get the Fibre Extra product, my current upload speed is 13mb + and I do not want to lose that.
04-07-2016 2:06 PM
Either login to member centre and click on the 'Product change' link: http://portal.plus.net/upgrade_process.html?memberheader=upgrade or call Customer Options and see if they'll do you a nice deal.
04-07-2016 2:34 PM
W23 thanks for the tip, problem has now been resolved after discussion with the customer team 😉
09-07-2016 9:12 AM - edited 09-07-2016 9:16 AM
Well I am sorry to report this is not fixed at all and in fact my service is now much worse.
I marked it as fixed as I had a satisfactory offer from retentions to retain the upload speed by moving me to Fibre Extra. However the Fibre Extra upload speed I am getting is approximately half that I was getting before the 'upgrade'. I have spoken to Support twice, the first on told me that it would settle and the second one told me there was nothing that could be done.
So I now have a product that is meant to be better but is actually much worse. Before the upgrade my speeds were approx 34/13 and now they are about 36/7 at best. Something has gone wrong and I am not happy.
Here is the line speed info for my line:
Telephone number:01603xxxxxx
Phone exchange:COSTESSEY
Estimated line speed:51Mb (This may vary between 37.9Mb and 51Mb) - Checked on 2016-07-04 15:25:42
Current line speed:38.2 Mb
What can be done?
How do I remove the 'Fixed' flag from this thread?
09-07-2016 2:58 PM - edited 09-07-2016 2:59 PM
Moderator's note by Mike (Mav)
I have unset the fix as the OP issue is ongoing.
Forum Moderator and Customer
11-07-2016 9:00 AM
There is no reason at all for your sync speeds to have altered, moving from 40/20 to 80/20 doesn't involve any orders or changes to the line it's simply a setting on our side.
Sync Status | In Sync |
Downstream Speed | 39.3 Mbps |
Upstream Speed | 8.2 Mbps |
Profile Name | 0.128M-80M Downstream, Error Protection Off - 0.128M-20M Upstream, Error Protection Off |
The speed may go up again, it may also decrease slightly though. As it's within the estimate range it's not something we can report as a fault.
Featured Products |
Downstream Line Rate(Mbps) |
Upstream Line Rate(Mbps) |
Downstream Range(Mbps) |
WBC FTTC Availability Date |
WBC SOGEA Availability Date |
Left in Jumper |
High | Low | High | Low | |||||
VDSL Range A (Clean) | 51 | 37.9 | 11.6 | 7.7 | -- | Available | -- | -- |
11-07-2016 9:07 AM - edited 11-07-2016 9:11 AM
I have to ask the obvious question
Why was the upstream reported as 13Mb/s in post 4 and it is now 8.2Mb/s
11-07-2016 10:04 AM
Prior to the change my upload speed was always above 10Mbps normally near to 13Mbps, please look at the speeds that I was getting before the change not what they are now. The now speeds are not consistent with my earlier service speeds.
11-07-2016 10:15 AM
Sync Status In Sync Downstream Speed 39.3 Mbps Upstream Speed 8.2 Mbps
Profile Name 0.128M-80M Downstream, Error Protection Off - 0.128M-20M Upstream, Error Protection Off
Featured Products
Left in Jumper
High Low High Low VDSL Range A (Clean) 51 37.9 11.6 7.7 -- Available -- --
The only reason for moving to the 80/40 speed was to retain my good upload speed and not to lose it with your imminent service 'upgrade' to 52/10 (which for many is a downgrade).
If nothing can be done then please revert my service back to 40/20 and cancel my 'new' 24 month contract and revert me to the position I was on before the new contract.
26-09-2016 2:18 AM
I want my service restored back to the way it was. I was previously getting about 36MB/s d/l and about 9Mb/s upload on the 40/20 provision. Now after the so-called upgrade, my download speed is no different, but my upload speed is now massively reduced to under 1Mb/s. Since I do community IT support which requires a decent remote desktop connection to my fileserver, and I'm trying to stream on Twitch, both of which requires at least 3-4Mb/s upload from my home network, I am no longer getting what I am paying for.
I DEMAND my previous service is restored or I am very seriously considering moving to another ISP.
I have been with Plusnet for 3 and a half years. They call it "Broadband that loves you back". It doesn't. They say they will "do you proud". They're not.
