Upload speed reduction - Stay with current product
wytco0
I understand that my broadband is going to be 'upgraded' by reducing the upload speed available? If this is correct how can I opt out of this upgrade.
Upload speed is more important to me than download and I do not wand my upload reduced. What options do I have?
12 REPLIES 12
Fixes: 62
Re: Upload speed reduction - Stay with current product
Assuming that you are already achieving better than 10Mb/s upload speed then the only option is Fibre Extra (80/20)
If you aren't then going from 40/20 to 55/10 won't have any effect
Chris
Legend
Fixes: 168
I'm afraid it's not an optional chance, as Oldjim states the way to keep the higher upload (assuming you're getting more than 10Mb/s at the moment) is to move to the Fibre Extra Product.
wytco0
So how do i get the Fibre Extra product, my current upload speed is 13mb + and I do not want to lose that.
Fixes: 4
Either login to member centre and click on the 'Product change' link: http://portal.plus.net/upgrade_process.html?memberheader=upgrade or call Customer Options and see if they'll do you a nice deal.
Call me 'w23'
wytco0
W23 thanks for the tip, problem has now been resolved after discussion with the customer team 😉
wytco0
Well I am sorry to report this is not fixed at all and in fact my service is now much worse.
I marked it as fixed as I had a satisfactory offer from retentions to retain the upload speed by moving me to Fibre Extra. However the Fibre Extra upload speed I am getting is approximately half that I was getting before the 'upgrade'. I have spoken to Support twice, the first on told me that it would settle and the second one told me there was nothing that could be done.
 So I now have a product that is meant to be better but is actually much worse. Before the upgrade my speeds were approx 34/13 and now they are about 36/7 at best. Something has gone wrong and I am not happy.
Here is the line speed info for my line:
Telephone number:01603xxxxxx
Phone exchange:COSTESSEY
Estimated line speed:51Mb (This may vary between 37.9Mb and 51Mb) - Checked on 2016-07-04 15:25:42
Current line speed:38.2 Mb
What can be done?
How do I remove the 'Fixed' flag from this thread?
Fixes: 389
Moderator's note by Mike (Mav)
I have unset the fix as the OP issue is ongoing.
Forum Moderator and Customer
Chris
Legend
Fixes: 168
There is no reason at all for your sync speeds to have altered, moving from 40/20 to 80/20 doesn't involve any orders or changes to the line it's simply a setting on our side.
Sync Status In Sync
Downstream Speed 39.3 Mbps
Upstream Speed 8.2 Mbps
Profile Name 0.128M-80M Downstream, Error Protection Off - 0.128M-20M Upstream, Error Protection Off
The speed may go up again, it may also decrease slightly though. As it's within the estimate range it's not something we can report as a fault.
Featured Products
Downstream Line Rate(Mbps)
Upstream Line Rate(Mbps)
Downstream Range(Mbps)
WBC FTTC Availability Date
WBC SOGEA Availability Date
Left in Jumper
  High Low High Low
VDSL Range A (Clean) 51 37.9 11.6 7.7 -- Available -- --
Fixes: 62
I have to ask the obvious question
Why was the upstream reported as 13Mb/s in post 4 and it is now 8.2Mb/s
wytco0
Prior to the change my upload speed was always above 10Mbps normally near to 13Mbps, please look at the speeds that I was getting before the change not what they are now. The now speeds are not consistent with my earlier service speeds.
wytco0
Sync Status In Sync
Featured Products
Left in Jumper
  High Low High Low
The only reason for moving to the 80/40 speed was to retain my good upload speed and not to lose it with your imminent service 'upgrade' to 52/10 (which for many is a downgrade).
If nothing can be done then please revert my service back to 40/20 and cancel my 'new' 24 month contract and revert me to the position I was on before the new contract.
DJGM1974
I want my service restored back to the way it was. I was previously getting about 36MB/s d/l and about 9Mb/s upload on the 40/20 provision. Now after the so-called upgrade, my download speed is no different, but my upload speed is now massively reduced to under 1Mb/s. Since I do community IT support which requires a decent remote desktop connection to my fileserver, and I'm trying to stream on Twitch, both of which requires at least 3-4Mb/s upload from my home network, I am no longer getting what I am paying for.
I DEMAND my previous service is restored or I am very seriously considering moving to another ISP.
I have been with Plusnet for 3 and a half years. They call it "Broadband that loves you back". It doesn't. They say they will "do you proud". They're not.
