Upload speed reduced after outage 2 weeks ago.
I have Unlimited Fibre Extra which was running at 48/52 Download and 6.5/7 Upload. There was an outage a few weeks back after which the Upload had reduced to 3/3.5. I assumed there may have been a technical issue and that it would correct itself over time, but 2 week's later it is still at 3. is this an unannounced permanent change or will it be put back up to the correct value?
I'm using a Netgear D8700 and I've attached an image of the connection stats.
3 REPLIES 3
Fixes: 933
Re: Upload speed reduced after outage 2 weeks ago.
Sorry to hear you're having issues with your upload speed.
Testing your line isn't identifying the cause of that. If you've done the checks here I'd recommend raising a fault to us here to investigate further. Let us know how you get on.
Ticket submitted: Question #152206233
Legend
Fixes: 168
I've responded to your fault ticket and passed this through for further investigation.
