Upload speed low
warmbells
Upload speed low
I've just done a BT speedtest and got the following results:-
Download speedachieved during the test was - 37.11 Mbps
For your connection, the acceptable range of speeds is 29.64 Mbps-37.05 Mbps .
Additional Information:
IP Profile for your line is - 37.05 Mbps
Upload speed achieved during the test was - 3.33Mbps
The data has been sent to the server.
Gerald Bramwell
sjptd
Re: Upload speed low
Try the Thinkbroadband tester.  http://www.thinkbroadband.com/speedtest.html ;
Some testers (including the BT Wholwsale one) understate upload speed, sometimes quite severely.  I'm not quite sure why.  At one time I had some testers estimating 4 or so upload when I was actually getting 18 or so.
It may well not be the tester, but worth trying.
Plusnet Staff
Plusnet Staff
Fixes: 159
Your upload sync is at 7.2Mbps which is around what I'd expect based on the estimates for your line. Around the time of the speedtest we saw quite a chunk of upload usage on your line, can you ensure that anything doing backups, uploads etc is stopped and try another speedtest?
 Chris Parr
 Plusnet Staff
danludlow
Hi, I've just added to an older post that my uplink speed has dropped in the last two days, about 3mbps, and I'm puzzled as to why.
In my experience the uplink is normally rock solid and reliable as an indicator of connection health. If I lose speed on the downlink, but the uplink stays put, I can be pretty sure that the slower Downlink is traffic related.
warmbells
Quote from: sjptd
Hi sjptd,
Have just don a thinkbroadband test and got these results:-
http://www.thinkbroadband.com/speedtest/results.html?id=1434196765626755355
Gerald
Plusnet Staff
Plusnet Staff
Fixes: 159
Similar question to my previous post really, there was around 1GB upload traffic between 11 and 12, was anything else running when you did the line test?
 Chris Parr
 Plusnet Staff
elfish
Shocked
Burst of around 81Mbps near the end of the test is strange. Are you connecting via wireless? That anomaly maybe due to some sort of buffering/anti-virus program.
Try the alternative speed test here:
http://www.thinkbroadband.com/speedtest/speedtest2.html
With regards to other devices using the connection, I had a Android mobile that would in the background, backup all the videos and images without me knowing. If you have any mobile devices connected, check to see if they are doing any backing up.
warmbells
Quote from: Chris
Just done another test as follows:-
Download speedachieved during the test was - 28.81 Mbps
For your connection, the acceptable range of speedsis 29.64 Mbps-37.05 Mbps .
Upload speed achieved during the test was - 3.01Mbps
The only time my usage monitor showed more than about10.00kbits was when it was doing the upload test.
Gerald
Plusnet Staff
Plusnet Staff
Fixes: 159
@warmbells
I can't see any issues other than the upload usage, between 1 and 2pm when you did that test there was 850MB of upload traffic. If there was none at the time of doing the test it might be worth reporting a fault to us.
 Chris Parr
 Plusnet Staff
danludlow
My upload speed dropped about 3Mbps last week, as I posted earlier here. Overnight, its lost at least .5Mbps seemingly. Less than a week ago, I was getting about 15mbps Up, today I'm getting barely 10Mbps it seems. That's some reduction, not a blip, and there has to be a reason for it, doesn't there.
elfish
Are you undertaking these tests wirelessly?
What modem are you running?
warmbells
Ethernet cable from router to PC
Router is Technicolor TG582n FTTC Fibre with BT modem
Adie:quote
elfish
Is the BT modem a ECI or Huawei?
It may be worth also checking what make of DSLAM you are connecting to. See link below:
http://www.kitz.co.uk/adsl/cabinet-lookup.htm
There are known issues with inter-compatibility between the makes of equipment used.
You may of been hit with the G.INP 'fix'.
warmbells
It is ECI, I don't know what cabinet yet only that it is cabinet 11 on the Swinton, Greater Manchester exchange,
Strange that only last year I was getting only abt 27Mg download but 8 Mg upload.
dick:quote
lf2k
A quick look on magsys shows you're on a Huawei cabinet using an ECI modem - this is likely to be caused by the GINP issue elfish mentioned.
You can either wait for it to improve on its own (no guarantee it will) or see if another router/modem will improve the situation... Sad
