Upload speed less than half the line profile
- Re: Upload speed less than half the line profile
25-05-2021 6:18 AM - edited 25-05-2021 6:18 AM
Can't complain about download speed but the upload speed is less than half the prpfile for my connection: 7-8mbps instead of 20.
25-05-2021 7:27 AM
@MickGardner The upload profile on VDSL2 (FTTC) is fixed at the maximum speed for the product i.e. 10 Mbps or 20 Mbps and does not change. The speed you achieve is entirely dependent on the modem/router sync speed and is not controlled by the profile.
Details of your router connection stats would help to establish if your somewhat low upload speed could be improved. If you are using the Hub1 I believe these are on the router Help desk page but I'm not familiar with the device so can't offer more help.
25-05-2021 7:38 AM
Does this help?
25-05-2021 7:59 AM - edited 25-05-2021 8:00 AM
@MickGardner That's what I wanted to see but it just confirms a low upload speed with the correct SNR margin of 6dB, the download speed is looking good but that has a reduced SNRM which improves the speed, that doesn't happen on the upload.
With those attenuation figures you must be quite close to the FTTC cabinet so I would expect better speeds, what modem /router are you using because those stats do not look like the Hub1 page.
Try this checker to see what speeds are expected for your phone number, but blank out your number in the result.....
25-05-2021 8:58 AM - edited 25-05-2021 8:59 AM
I'm using an Archer VR400 router - I replaced the Plusnet supplied one as the WiFi was unreliable.
25-05-2021 9:01 AM - edited 25-05-2021 9:04 AM
Screenshot
25-05-2021 9:20 AM
I assume that you are testing your speed over an Ethernet cable and not wireless?
25-05-2021 9:26 AM
Yes, I am.
25-05-2021 11:55 AM
Hi @MickGardner,
I've tested your line this morning and whilst everything is running at a rate we'd expect and we wouldn't consider this to be a fault, things are towards the lower end of the expected speeds. The testing hasn't indicated why this might be the case, so it may be worth running through our troubleshooting steps here and here, to see if these make any difference. If the speed seems to deteriorate at all, please let us know and we'll be happy to assist.
