Upload speed higher than Download speed
- Upload speed higher than Download speed
29-01-2015 9:04 PM
Hi Guys
Running tests today. Upload speed is higher than Download speed. 10Mbps upload and 9Mbps download. It seemed to start off well but looks like its gradually dropping. Fibre installed 15th Jan. Changed to fibre as for 2 years had nothing but bother with ADSL. I hope I am not going to have the same problems with fibre. Reset the router was getting 2 + 3 then 7 + 8. Any ideas to what else can I do.
Cheers
Cheers
Message 1 of 4
(917 Views)
3 REPLIES 3
Re: Upload speed higher than Download speed
30-01-2015 11:00 AM
Your line's currently synced at
Downstream Speed 65.6 Mbps
Upstream Speed 13.4 Mbps
So you should certainly be seeing higher speeds than you are.
However, your line is disconnecting more than I'd like to see:
Can you go through the faults checker for us as something isn't right https://faults.plus.net
Message 2 of 4
(560 Views)
14-02-2015 7:06 PM
I have not been anywhere near this since I posted. Nothing has been turned off and it is exactly the way it was when engineer fitted it part from putting the BT router on 5Kbps download speed 7pm tonight. 10Kbps upload. Paying for a service I'm not getting. Advice appreciated on what to do next. Cheers
Message 3 of 4
(560 Views)
14-02-2015 8:17 PM
I suggest you click on the hyperlink and report the fault as suggested by Chris
To do is to be - Neitzsche
To be is to do - Kant
do be do be do - Sinatra
Message 4 of 4
(560 Views)
