Upload speed dropped to 1mb/s
- Upload speed dropped to 1mb/s
23-09-2015 2:09 AM
I have had this problem for a while. My upload speed was around 10mb/s but has dropped to under 1. I previously raised a fault and was given a second tg582n router. Changing the router fixed the upload speed but only for a limited time and it drops back down to under 1mb/s again. Whenever I switch the routers over the upload speed is temporarily fixed, but every time it drops back down. The download speed remains perfectly fine however.
Message 1 of 4
(1,016 Views)
3 REPLIES 3
Re: Upload speed dropped to 1mb/s
23-09-2015 4:20 PM
Message 2 of 4
(758 Views)
23-09-2015 5:55 PM
Yes I've tried rebooting both. It only seems to fix temporarily when I switch the routers around.
Message 3 of 4
(758 Views)
23-09-2015 6:03 PM
The sync speed relates to the Openreach modem so it shouldn't make any difference.
I'd recommend raising a fault here
https://faults.plus.net
Message 4 of 4
(758 Views)
