Upload speed dropped to 0.06Mbps
andyblac
my web browsing has gone terable, so i did speed test using BT Wholesale speed test, it says my down is 34.65Mbps (correct), but my upload is 0.06Mbps and ping time 114.38.
what is going on, anyone else having issues?
Fixes: 62
Re: Upload speed dropped to 0.06Mbps
That is most unusual
Are you sure that something isn't saturating your upload - P2P would be the usual culprit
andyblac
nope, i don't use p2p, nothing going on at all, i can tell by the DSL lights on modem.
stats from router:
Interface Traffic Statistics
Interface Rate Rx (Kbps) Rate Tx (Kbps) Packets Rx (Pkt) Packets Tx (Pkt) Bytes Rx (Byte) Bytes Tx (Byte)
WAN1 146.186 24.214 761,975 407,788 995,446,533 63,619,226
LAN 26.687 140.198 470,573 819,460 70,020,989 1.06e+9
speedtest.net is slightly better
andyblac
just did a hardware reset of router, problem solved, not sure what happened maybe config got corrupt.
Fixes: 203
Glad to hear you got it sorted.
 Matthew Wheeler
