Upload speed dropped to 0.06Mbps
- Re: Upload speed dropped to 0.06Mbps
18-09-2015 9:05 PM
my web browsing has gone terable, so i did speed test using BT Wholesale speed test, it says my down is 34.65Mbps (correct), but my upload is 0.06Mbps and ping time 114.38.
what is going on, anyone else having issues?
Message 1 of 5
(1,083 Views)
4 REPLIES 4
18-09-2015 9:15 PM
That is most unusual
Are you sure that something isn't saturating your upload - P2P would be the usual culprit
Message 2 of 5
(912 Views)
18-09-2015 9:56 PM
nope, i don't use p2p, nothing going on at all, i can tell by the DSL lights on modem.
stats from router:
Interface Traffic Statistics
Interface Rate Rx (Kbps) Rate Tx (Kbps) Packets Rx (Pkt) Packets Tx (Pkt) Bytes Rx (Byte) Bytes Tx (Byte)
WAN1 146.186 24.214 761,975 407,788 995,446,533 63,619,226
LAN 26.687 140.198 470,573 819,460 70,020,989 1.06e+9
speedtest.net is slightly better
stats from router:
Message 3 of 5
(912 Views)
18-09-2015 10:26 PM
just did a hardware reset of router, problem solved, not sure what happened maybe config got corrupt.
Message 4 of 5
(912 Views)
19-09-2015 10:35 AM
Message 5 of 5
(912 Views)
