Upload speed Dramatically Dropped!
geekofbroadband
So my Hub was up for around 19 days without an issue, then I noticed it rebooted in the middle of the night and my upload has gone from 19Mbs to 13Mbs. Reboot / Factory Reset / Changing modem/router didn't work.
geekofbroadband
Re: Upload speed Dramatically Dropped!
Stats from Hub One:
3. Firmware version: Software version 4.7.5.1.83.8.226 Last updated 15/10/16
4. Board version: Plusnet Hub One
5. DSL uptime: 0 days, 00:28:04
6. Data rate: 14321 / 66089
7. Maximum data rate: 14530 / 66344
8. Noise margin: 6.1 / 6.1
9. Line attenuation: 11.9 / 12.1
10. Signal attenuation: 11.7 / 12.1
Fixes: 20
Do you happen to have any old stats (from a different device) which show the cabinet firmware version, so that you could compare it to now?
geekofbroadband
I'm not sure how to do that, I have a Zyxel VMG8924-B10A Im not using, would that work?
Fixes: 20
Yes, anything that has full telnet to do xdslcmd info --vendor (or whatever the xdsl/adsl/xdslcmd/xdslctl command is).
The middle of the night is probably when the cabinet firmware would get updated.
geekofbroadband
http://i.imgur.com/RNzSN5L.png
Using adsl info --vendor
geekofbroadband
Can someone from Plusnet tell me whats going on please?? Can you do a line check, Ive randomly lost 5-6Mbs on my upload for no reason, I may as well downgrade my package...
Plusnet Staff
Plusnet Staff
Fixes: 117
Thank you for your PM and for your patience @geekofbroadband
I've tested your line,
Sync Status In Sync
Downstream Speed 64.0 Mbps
Upstream Speed 15.1 Mbps
Both your sync speeds are below the estimates,
FTTC
Product status: Enabled
Product RAG: Green
Reason code: G - FTTC is already enabled on this line
CAB #: 4
Speed (Clean) : 80000 - 67400
Upstream: 20000 - 20000
Speed (Impacted) : 78100 - 49000
Upstream: 20000 - 16800
I'd advise to next try connecting the router into the test socket, if you haven't already. Explained here: https://community.plus.net/t5/Library/Testing-From-The-Master-Socket/ba-p/1322242
If this doesn't help then raise a fault to us at http://faults.plus.net as it's likely going to require an engineer.
From when I joined the Plusnet Help Team in May 2017 my main Community account is @Gandalf.
 Plusnet Staff
geekofbroadband
Tried the test socket, speed became worse so Im going to make a ticket. Will the engineer come to the house or does he just go to the cabinet? Thanks
Fixes: 162
It depends on what the test results show, we can't really say with any guarantee in advance.
 Chris Parr
 Plusnet Staff
