Upload issues ( from Re: Not getting quoted upload speed)
martyuk1975
HI Darkfire,
I have not long joined PlusNet and I am also having problems with uploading. I was with Sky before and had no issues. The download speed is great but I'm only getting 1.8 upload speed. and When I 'm uploading a larger file say to mix cloud etc? the connection bombs out and the router resets? can you help?
rongtw
Fixes: 11
@martyuk1975  have a read here ,, https://community.plus.net/t5/Fibre-Broadband/Plusnet-fibre-broadband-does-not-cope-with-uploads-and...
Fixes: 117
Moderators Note.
split out from an old thread for better visibility
Will Moderate For Thanks
Plusnet Staff
Plusnet Staff
Fixes: 159
Re: Upload issues ( from Re: Not getting quoted upload speed)
The upload speed at 1.8Mb/s is correct for the product you're on. The connection dropping is an issue we're investigating as per the link @rongtw has provided. Sorry for the issues.
 Chris Parr
 Plusnet Staff
martyuk1975
Thanks for looking into that. It's really a problem Sad... I'm not to fussed about the speed of upload just as long as it works etc.. Roll eyes
