Upload issues ( from Re: Not getting quoted upload speed)
- Upload issues ( from Re: Not getting quoted upload...
on 09-02-2017 5:09 AM - last edited on 09-02-2017 7:40 AM by dvorak
HI Darkfire,
I have not long joined PlusNet and I am also having problems with uploading. I was with Sky before and had no issues. The download speed is great but I'm only getting 1.8 upload speed. and When I 'm uploading a larger file say to mix cloud etc? the connection bombs out and the router resets? can you help?
09-02-2017 6:49 AM
@martyuk1975 have a read here ,, https://community.plus.net/t5/Fibre-Broadband/Plusnet-fibre-broadband-does-not-cope-with-uploads-and...
09-02-2017 7:39 AM
split out from an old thread for better visibility
Re: Upload issues ( from Re: Not getting quoted upload speed)
09-02-2017 3:12 PM
The upload speed at 1.8Mb/s is correct for the product you're on. The connection dropping is an issue we're investigating as per the link @rongtw has provided. Sorry for the issues.
10-02-2017 11:04 PM
Thanks for looking into that. It's really a problem :(... I'm not to fussed about the speed of upload just as long as it works etc..
