Upload faster than download - reversed when using speedtest details.
choccylab
Morning.
I've just had an engineer attend to fix the fault with my phone line - there had been no dial tone.  He replaced the SSFP Infinity plate with a new one and the phone started working again.  Now I have an issue with my broadband.
I performed the BT Wholesale tests as directed and found the results were almost reversed when using the BT details for the second round.
First of all with my usual details
Download speed achieved during the test was - 5.64 Mbps
For your connection, the acceptable range of speeds is 40 Mbps-55.3 Mbps .
Additional Information:
IP Profile for your line is - 55.3 Mbps
Upload speed achieved during the test was - 15.49Mbps
Using speedtest@speedtest_domain - note how the situation appears reversed.
Your service was found to be performing poorly.
Please raise a fault with your service provider, stating that the BT Performance Tester tool indicates poor service throughput performance after the third test.
Download speed achieved during the test was - 41.79 Mbps
Upload speed achieved during the test was - 3.16Mbps
I have switched off the modem etc for 5 minutes and then repowered and there is no difference.  These tests were carried out on a desktop hard wired into the router.  I have also tested with a laptop hard wired in and the results are very similar.  Help would be appreciated please.
Fixes: 239
Re: Upload faster than download - reversed when using speedtest details.
The profile on our end needed updating.
Can you test it in the next 15 minutes?
 Matthew Wheeler
choccylab
Hi
I certainly can.  I will run the same set of tests and let you know what I find.
Many thanks
choccylab
Latest test showed 53mb down and approx 18mb up.  Thank you very much indeed!
Fixes: 239
Glad to hear it!
 Matthew Wheeler
