Upload crashes HG533 router.
- Upload crashes HG533 router.
30-11-2015 8:53 PM
I have 80/20 FTTC - actual speeds are around 43/18 which is good enough as uploads are more important.
I choose not to use the 2704N as it is particularly useless and way too tied down to make it do what I need.
I am currently using my old TalkTalk HG533 in 'fibre' mode' - it worked - without fault on the TT ADSL when they were my provider.
Whenever I do any significant FTP uploads the TT router crashes completely after anything between 10 and 30 mins.. I cannot even ping the router so I have to power cycle - which is a bit annoying as I'm hosting various servers.
Has anyone else experienced an issue with uploads crashing a/the router and is there any way to avoid this issue?
Cheers
Tim
Cheers
Tim
Message 1 of 5
(1,006 Views)
4 REPLIES 4
Re: Upload crashes HG533 router.
30-11-2015 10:01 PM
Buy a better router. There's a pretty wide choice out there and personally I'd avoid anything that was re-badged. Most ISPs that provide a router free of charge will supply the cheapest router they can find.
Quote from: algaeholics Has anyone else experienced an issue with uploads crashing a/the router and is there any way to avoid this issue?
Message 2 of 5
(683 Views)
01-12-2015 9:19 AM
It sounds like the router is overheating when you stress it. Could be down to a build up of dust inside the router and maybe helped by blowing compressed air through the device. Cans be be bought at Maplin or Currys are called airdusters
However if it is heat related then the router may have been pushed too far and need replacing. Might be worth a try spending £7 or £8 to see if it helps first.
Message 3 of 5
(683 Views)
01-12-2015 1:59 PM
The router is not overheating - quite cool (8)) actually. I've ordered a TP-Link TL-WR1043ND anyways - hopefully this will not have the same issue.
Message 4 of 5
(683 Views)
02-12-2015 4:39 PM
Replying to myself here, but I have the new router http://www.cclonline.com/product/39856/TL-WR1043ND/Cable-Routers/TP-Link-Ultimate-Wireless-N-Gigabit... and it's very easy to setup - even for the advanced options and - so far.... the uploads are working just fine...
Thanks for all the responses.
Message 5 of 5
(683 Views)
