Upload Speed
adilcanm
Upload Speed
Hello,
My upload speed was around 15mbps on my first month with plusnet, since 2-3 weeks, it is down to 3mbps. How can I increase it?
Moderator's note by Mike (Mav): All caps title edited as per Forum rules.
Fixes: 55
Re: Upload Speed
Were you connected over WiFi or a wired connection when you noticed this?
 Adam Walker
adilcanm
Re: Upload Speed
I was on my computer, connected by LAN cable
Fixes: 55
Re: Upload Speed
Cheers,
Diagnostic checks show that the upstream line rate is at about 7mbps which is well below what's estimated for your line so it's best that we try and rule out anything within your premises that may be a cause next.
Could you try connecting into the test socket (assuming your master socket has this) https://community.plus.net/t5/Library/Testing-From-The-Master-Socket/ba-p/1322242 and test again here please? www.speedtest.btwholesale.com/
Keep us posted.
 Adam Walker
adilcanm
Re: Upload Speed
I am not at home, I will let you know in 4-5 hours. Thanks for your help
Fixes: 55
Re: Upload Speed
No worries, I'll look out for you getting back to us.
 Adam Walker
adilcanm
Re: Upload Speed
Hello,
I couldn't unscrew it Sad I will get my son to do it for me
Fixes: 348
Re: Upload Speed
No worries, keep us posted!
