Upload Speed
u123072
Upload Speed
Hello.
My upload speed seems to have dropped.
Speed tests continually measure a maximum of 0.76Mbps which seems low for my line and package (unlimited fibre).
Download speeds are good at between 40 and 50Mbps.
Please could you check my settings.
Fixes: 64
Re: Upload Speed
I've just been looking into this and line tests aren't indicating any issues as to why the upload is so low but that in itself does need looking into.
Just to make sure everything possible has been tried out on your side can you make sure the checks here have been followed please? https://goo.gl/tu2WWu
If there's still an issue following that it would be best to report a fault over at http://faults.plus.net before dropping me a reply back here.
 Adam Walker
u123072
Re: Upload Speed
Thanks Adam.
There is some noise (hiss & crackle) on the line.
I have re-run the test several times with the same results.
I have raised a fault - 158805238
