Upload Speed
- Upload Speed
- « Previous
- 1
- 2
- Next »
Re: Upload Speed
03-09-2015 12:45 PM
There's no DLM banding on the line.
"0.128M-80M Downstream, Retransmission Low - 0.128M-20M Upstream, Error Protection Off"
And in addition the estimated range for upload on the OP's line is between 6.4mbps and 10mbps.
Message 16 of 20
(221 Views)
Re: Upload Speed
03-09-2015 12:45 PM
interesting in my case I get
Connection speed (kbps): 48446 10569
and from http://www.thinkbroadband.com/guide/fibre-broadband.html my upload is about right but my download speed is much higher - 800m cable length
Seeing Matt's post I suspect that interleaving has been applied to the upload which could cause a drop in speed
Message 17 of 20
(221 Views)
Re: Upload Speed
03-09-2015 12:49 PM
Can this be sorted out then,thanks
https://www.flickr.com/photos/james_bingham/
Message 18 of 20
(221 Views)
Re: Upload Speed
03-09-2015 12:53 PM
If I am correct in the diagnosis then unfortunately it can't so you are stuck with it and changing suppliers won't help in this case
Message 19 of 20
(221 Views)
Re: Upload Speed
03-09-2015 12:54 PM
Ok cheers.
Message 20 of 20
(221 Views)
- « Previous
- 1
- 2
- Next »
