Upload Speed
- Re: Upload Speed
Upload Speed
03-09-2015 9:37 AM
1. Best Effort Test: -provides background information.
Download Speed
37.79 Mbps
0 Mbps 54.73 Mbps
Max Achievable Speed
Download speedachieved during the test was - 37.79 Mbps
For your connection, the acceptable range of speedsis 40 Mbps-54.73 Mbps .
Additional Information:
IP Profile for your line is - 54.73 Mbps
Upload Speed
6.7 Mbps
0 Mbps 20 Mbps
Upload speed achieved during the test was - 6.7Mbps
This test was not conclusive and further testing is required.This might be useful for your Broadband Service Provider to investigate the fault.
If you wish to carry out further tests,please click on 'Continue' button.If not, please close the window using 'Exit' button and contact your ISP for further assistance with these results.
Please visit the FAQ if you are unable to understand the test results.
adie:red removed all caps title as per link:rules ]
Re: UPLOAD SPEED
03-09-2015 9:40 AM
The product you are on is 80/20 and the max achievable speed is always shown as 20Mb/s as there isn't an upstream IP profile
Having said that your speed test results are lower than they should be - were they tested wired or wireless
Re: UPLOAD SPEED
03-09-2015 9:43 AM
I don,t use wifi
Re: Upload Speed
03-09-2015 10:04 AM
The first thing is to find out why your download speed is so far below your IP profile
What does the current line speed report - see my sig for a link
As an aside - your sig breaks the forum rule by a fair chunk
Re: Upload Speed
03-09-2015 11:02 AM
Re: Upload Speed
03-09-2015 11:05 AM
Re: Upload Speed
03-09-2015 11:45 AM
Re: Upload Speed
03-09-2015 12:07 PM
The speed test result is far too low compared to the IP profile and that is what needs sorting hence asking what the Current Line Speed is set to
With that downstream IP profile I would have expected upload speeds to be over 10Mb/s
Re: Upload Speed
03-09-2015 12:07 PM
Re: Upload Speed
03-09-2015 12:08 PM
So would i.
Quote from: Oldjim Actually that wasn't what I was saying
Phone exchange:
MUIRKIRK
Estimated line speed:
33Mb (Download speed could vary depending on line conditions. Estimates are the maximum speeds that your phone line can support. These speeds are dependent on the package you choose.) - Checked on 2015-06-06 13:00:04
Current line speed:
40 Mb
Re: Upload Speed
03-09-2015 12:14 PM
Quote from: Oldjim The speed test result is far too low compared to the IP profile and that is what needs sorting hence asking what the Current Line Speed is set to
er, isn't that what I said?
Re: Upload Speed
03-09-2015 12:17 PM
Why is the downstream test low - you are apparently on the 40/20 product
Having said that it doesn't explain why the upstream speed test result is low
Can you try these tests and report the results
http://www.mybroadbandspeed.co.uk/
http://www.thinkbroadband.com/speedtest.html?utm_source=mainsite&utm_medium=navigation&utm_campaign=...
Re: Upload Speed
03-09-2015 12:40 PM
d/l 37823 up 6975
2nd one d/l 38.2 up 7.4
Re: Upload Speed
03-09-2015 12:41 PM
Re: Upload Speed
03-09-2015 12:43 PM
