Upload Speed Problem
FIXED- Subscribe to RSS Feed
- Upload Speed Problem
18-07-2021 10:38 PM
Hi ive recently taking to streaming on Twitch and my upload speed sits around 6mbps which is fine and I use 4000 bitrate to stream now my problem is that at random my upload will drop to about 300 kbps and the stream will drop a massive amount of frames seems a bit weird considering that I used to stream a few years ago and it was smooth as butter with all the same settings and I could stream all day and not a single frame would drop please can someone help me I'm getting a bit fed up now
Fixed! Go to the fix.
Re: Upload Speed Problem
19-07-2021 7:37 AM
Moderators Note
This topic has been moved from Chat to Fibre
19-07-2021 5:38 PM
Hi @SteveWilliams61, thanks for getting in touch and I'm sorry to hear you're having issues with wavering speeds as of recent. Testing your connection from this side currently I can see we're currently getting 40Mbps download and 6.4Mbps upload to your router with no signs of underlying faults.
Just to confirm first of all then, the device you're streaming off, is this wired into the router or is this connected via wireless?
Also, the times when you're noticing the upload drop to a crawl, are there any heavy downloads or higher usage of the connection at the time which could explain some of the performance issues? I ask as generally, if you're downloading or uploading a large file then your connection will look to do so with as much bandwidth as possible. If you're streaming at this point which requires a certain upload speed for higher quality would mean then be impacting as your connection will use everything it has for the larger download leaving less upload speed and performance issues with your stream.This can sometimes be combatted by saving large downloads or updates for periods when you're not streaming.
I look forwards to hearing from you further.
20-07-2021 8:11 PM
Hi and thanks for the quick response, I can confirm the device is wired not wireless and there are no large downloads running at the same time when the upload speed dropping occurs. I called up Plusnet yesterday and had a chat about the issue and the gentleman said he would change my line profile to make it more stable because I heard from a friend who works in the industry that there are 3 line profiles and mine might have been too aggressive for my line to cope with, he also said the change might take up to 48hrs to complete upon further testing though it might be fixed already fingers crossed.
21-07-2021 9:25 AM
Thanks for getting back to us @SteveWilliams61
I'm sorry to see you're having problems with your upload speed. I'm glad to see the changes we've made to your line's profile to increase the stability looks to have sorted this out for you.
If you're still having issues though, it may be worth looking at the router next to see if that's causing an issue.
Are you using the Openreach modem and Technicolor router combo we sent you long ago?
If that's the case, I'd like to send you more modern piece of kit.
21-07-2021 12:02 PM
Hello again and no we still use the Openreach modem but with an Asus Router that seems to be pretty solid but if you think it would be worth sending us something new then I don't see a problem
21-07-2021 1:39 PM
Hi Steve, ah no problem. As your sync speed going into the Openreach modem looks to be OK, I wouldn't say there's an issue with the modem, and as things are OK now with your Asus router, it may be worth us hanging fire on sending a Hub One, because the Asus is likely going to be a much more capable router (in terms of Wi-Fi).
Let us know if that changes though.
23-07-2021 12:43 AM
Is it at all possible for you guys to run a Line test so I can see the stats for my line someone did one for me like 2-3 years ago but I would like to see an updated one, please
Many Thanks
Steve
23-07-2021 10:44 AM - edited 23-07-2021 10:46 AM
Good morning @SteveWilliams61, no problem at all . I've run some tests on the line and have popped them below. the line looks fine, though your upload speed seems a little low. An RRT test shows no line issues though, and technically speaking, it is within estimates as per BT's Availability Checker, I've also run a Radius test which shows the odd disconnection, though nothing major to worry about here as well.
23-07-2021 3:23 PM
Thanks for doing the line test much Appreciated also yes my upload is a bit slow considering that when I joined back in 2013 it was 11mbps then over the years it's slowly decreased not the end of the world but worth noting
23-07-2021 3:55 PM
Thanks for your response @SteveWilliams61
I agree, while it's technically within range / estimates for your line, it is on the low end. Please let us know if it decreases below 6.3Mbps ((wired), we'll be able to investigate further and possibly raise the matter with Openreach.
