Upload Caps
JohnDalton
Upload Caps
Hello,
Long term customer and curious to know if you still cap upload speeds unless requested? Only reason I ask is because I'm trying to start live streaming again.
Fixes: 62
Re: Upload Caps
There is no upload cap  per se on fibre but the upload speed is up to 2Mb/s on fibre and up to 20Mb/s on fibre extra
JohnDalton
Re: Upload Caps
I'm on fibre extra with about 8mb up and 40-50mb down.
Fixes: 62
Re: Upload Caps
so you won't have a problem
Fixes: 385
Re: Upload Caps
Hi John,
As has advised if you're on Unlimited Fibre Extra, you're package isn't capped. Just tested your line and your router is in sync at a pretty good speed, at the top end of your estimates.
Sync Status In Sync
Downstream Speed 49.2 Mbps
Upstream Speed 8.0 Mbps
Let us know if you have any questions or issues.
JohnDalton
Re: Upload Caps
Was debating if I was being capped or not. Speeds are pretty low comparing to my old speeds which are a stones throw away, might have to look into switching provider at some point.
Fixes: 10
Re: Upload Caps
Changing provider won't change your upstream sync (unless you move the Virgin cable).
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
