Upgrding To Fiber
RD
Upgrding To Fiber
Hi Every one
I am new here
I have recently change from standard broadband to fiber
On the 15th of July I received a email saying that my change had been completed.
On the 22nd of July I received an email saying that my upload speed had been completed. (It has been change to 2mb)
My Question is
I am still on standard download speed of just over 7mb. Instead of the 30mb to 40mb I should be getting.
Any help would be greatly appreciated.
10 REPLIES 10
Oldjim
Resting Legend
Fixes: 63
Re: Upgrding To Fiber
Check Current Linespeed here https://portal.plus.net/my.html?action=data_transfer_speed
If it is still the ADSL number try Chat to get them to fix it
RD
So after spending 30 mins on the phone to get through to someone.
They say I have got to play with wireless channels to get a better signal.
Terranova667
Fixes: 5
Ok what does it say via the link that Old Jim gave, also run the BTW speed test ignore the red writing, once it's finished pick Further diagnostics and post the results.  http://speedtest.btwholesale.com/
this will show if your actually getting the speed you should be getting and we can go from there.
RD
The link Jim gave me says
Estimated line speed:40Mb (This may vary between 73.4Mb and 80Mb) - Checked on 2016-07-09 19:46:59Current line speed:38.6 Mb
I have tried 3 times to do a further diagnostics test
It said that it timed out 2 times and that there was a error on one of them.
Oldjim
Resting Legend
Fixes: 63
can you try this one as well - it may just work - http://www.speedtest.btwholesale.com/PerformanceTesterWS/diagnostics.do (you need the top option)
RD
Hi Jim
Just restarted my computer and try again on both links provided
It just keeps coming up with timed out.
RD
Hi
Just connect an Ethernet cable to my laptop and it worked.
How do I post the results to the forum.
sorry not the best with laptops.
RD
1. Best Effort Test: -provides background information.
  Download Speed
  8.62 Mbps
0 Mbps 38.71 Mbps
Max Achievable Speed
 Download speedachieved during the test was - 8.62 Mbps
 For your connection, the acceptable range of speedsis 20 Mbps-38.71 Mbps .
 Additional Information:
 IP Profile for your line is - 38.71 Mbps
  Upload Speed
  1.28 Mbps
0 Mbps 2 Mbps
Upload speed achieved during the test was - 1.28Mbps
 Upstream Rate IP profile on your line is - 2 Mbps
This test was not conclusive and further testing is required.This might be useful for your Broadband Service Provider to investigate the fault.
MatthewWheeler
Fixes: 479
Your connection hasn't dropped since the profile on our end updated.
Can you reboot the router or log into it to disconnect and then reconnect?
That should sort it.
 Matthew Wheeler
RD
All sorted
  Download Speed
  51.33 Mbps
0 Mbps 38.71 Mbps
 Download speedachieved during the test was - 51.33 Mbps
  Upload Speed
  1.25 Mbps
0 Mbps 2 Mbps
Upload speed achieved during the test was - 1.25Mbps
We were unable to identify any performance problem with your service at this time.
It is possible that any problem you are currently, or had previously experienced may have been caused by traffic congestion on the Internet or by the server you were accessing responding slowly.
If you continue to encounter a problem with a specific server, please contact the administrator of that server in the first instance.
Thanks everyone for there help and patience with me and computers.
