Upgrading to fibre this week, should I be worried about need for extension
- Upgrading to fibre this week, should I be worried ...
31-05-2015 4:30 PM
I moved from sky to pn only this months and immediately found pn offered me fibre whereas sky don't, so upgraded immediately. Install due Friday coming. Thing is I have an old house with the old GPO phone box now mounted in what is a downstairs loo. I run a phone extension from it to my meters cupboard on the other side of my hallway hidden behind some plastic routing given no power in the loo of course. I then have the current pn router and an 8 port gigabit hub feeding many links in the house.
I ordered the extension install for fibre but worried it may be ugly or not achievable given my setup. Also I won't be at my property, my wife will, and thus my fussy nature of clean installs won't be present
What's the story on the extensions? Can pn use the existing one? Can they bury a new one in the current masking route?
Finally I ordered a new router with the install as wasn't sure if the same one as adsl on pn, are they the same?
Thanks for any thoughts.
Message 1 of 3
(579 Views)
2 REPLIES 2
Re: Upgrading to fibre this week, should I be worried about need for extension
31-05-2015 5:18 PM
The routers are different so you were correct to order a new one.
I'm sure that the engineer will put the new cable in the ducting & position the modem by the powerpoint & connect it to the new BT socket. Ask your wife to smile sweetly & have the kettle on & I'm sure everything will go OK. She might even listen as you carefully explain to her exactly what needs to be done!!
Message 2 of 3
(349 Views)
01-06-2015 11:20 AM
Cheers very reassuring.
Message 3 of 3
(349 Views)
