Upgrading to Fibre with no Master Socket
- Upgrading to Fibre with no Master Socket
12-01-2016 3:14 PM
Hi - apologies if this is discussed elsewhere.
I've been with PlusNet for donkeys years and have a 2740N router plugged in to a micro filtered extension socket chugging away nicely. I do not have a BT master socket as such, my phone line comes in to my attic and is joined to a junction box and then joined to the extensions.
Will I be able to upgrade to fibre by plugging my router into the BT fibre modem and then into the extension socket using a filter? I appreciate that this may be detrimental to my speed but it's working ok now.
Message 1 of 3
(1,048 Views)
2 REPLIES 2
Re: Upgrading to Fibre with no Master Socket
12-01-2016 4:58 PM
BT Openreach no longer provide a fibre modem as Plusnet provide a combined VDSL Modem/Router (Plusnet Hub One).
If you ask for a self install fibre upgrade then you will be able to plug in the new Plusnet Hub One modem/router into any extension socket using a filter.
Message 2 of 3
(514 Views)
08-02-2016 5:56 PM
Quote from: acr If you ask for a self install fibre upgrade then you will be able to plug in the new Plusnet Hub One modem/router into any extension socket using a filter.
Anyone know how you ask for self-install? It's not something I saw when going most of the way through the process to change product. It just suggests a bunch of time slots for the engineer visit.
cheers
Andy
Message 3 of 3
(514 Views)
