Upgraded to fibre, still getting ADSL speeds
- Re: Upgraded to fibre, still getting ADSL speeds
07-04-2016 12:07 PM
My service was apparently switched over to fibre on the 5th of April, and my Hub One arrived today.
I plugged it in but my speed has remained the same.
Will my speed be upgraded in the future?
07-04-2016 12:12 PM
Possibly you got the email about being upgraded a bit early? Did plusnet give you a set date when due to upgrade?
Hopefully staff will pick up this thread!
If you Like it, give it a
07-04-2016 12:13 PM
07-04-2016 12:17 PM
I'd keep the hub one plugged in, saves the switching of routers! it operates fine on ADSL and when the fibre is completed you don't even need a reboot
07-04-2016 12:18 PM
Ah, thank you. That's good to know.
07-04-2016 12:20 PM
