Upgraded to fibre connection
- Upgraded to fibre connection
12-07-2017 8:12 PM
My fibre upgrade completed yesterday, no sign of my new Plusnet router yet so I'm using my existing TPLink TP-WD9970 which is capable of VDSL2.
My old ADSL stopped working on the update day but I cannot connect to VDSL.... Now, if I tell my Modem to search for any xDSL sync it will select ADSL but no data can be transmitted, if I manually tell it to search for VDSL it will not connect at all.
Can you suggest anything to try?
Thanks.
Re: Upgraded to fibre connection
12-07-2017 8:27 PM
You haven't been upgraded yet if your router still syncs on ADSL. What notification did you get that the upgrade was complete? I got an email saying your product change has completed but it only applied to the broadband account and not the actual connection. It seems strange that your ADSL is no longer working, something has been changed but looks like BT Openreach have got something wrong. You need help from the forum staff.
12-07-2017 8:36 PM
Thanks for your help. Yes, I got an email on the day it was due to complete (11th) saying that product change is complete and outlining the username etc. the Order Tracker in the member centre says it's complete.
13-07-2017 1:07 PM - edited 13-07-2017 1:07 PM
Sorry to hear you're experiencing problems connecting @rileyelf,
Looking at your account, your fibre order did complete on the 11th as expected. Testing the connection shows authentication attempts, but shows the connection out of sync with advice stating the router is potentially not configured correctly.
Could you confirm that all of the following settings are correct in your router:
It asks for: | Use: |
Broadband username or login name | yourusername@plusdsl.net |
Connection type or encapsulation | PPPoE Always On |
Password | The password you use to log in to the Member Centre |
VLAN | Active |
VLAN ID (802.1q) | 101 |
VLAN ID (802.1p) | 0 |
13-07-2017 2:48 PM
@rileyelf If all else fails go through the quick setup on the 9970 as in the example here http://wiki.kitz.co.uk/index.php/TD-W9980_QuickSetup there should be a PlusNet_VDSL option in the ISP list. Select that and it will set the VLAN correctly. Then all you need to do is eneter your username/password as described by @HarryB
13-07-2017 3:05 PM
Thanks for the suggestions, I will try again tonight.
I have tried setting it up manually and using the Quick setup, neither worked... What worries me is that if I tell the router to autosync (not tell it which modulation scheme to use) it will connect to ADSL, if my understanding is correct when the change to Fiber happened ADSL should have been turned off at the exchange.
Will have a play again tonight.
13-07-2017 3:19 PM - edited 13-07-2017 3:22 PM
Your understanding IS correct. AFAIK an FTTC upgrade would involve un-patching the line from ADSL at the exchange and then patching the line at the cabinet to the adjacent FTTC cabinet If it is still synching on ADSL then it sounds like the Fibre install hasn't been done correctly.
14-07-2017 8:45 AM
14-07-2017 9:09 AM
I doubt there is much more you can do from your end. Hopefully a staff member will be along soon to check out what's going on with your account.
I see @Gandalf is on line today.
14-07-2017 9:20 AM
I'm not quite sure I understand how that is happening...
14-07-2017 10:29 AM
I was just about to post a similar query.
@HarryB If the OP has only has ADSL sync how can authentication attempts have been made, then you say the router is out of sync which would also prevent authentication. Something not quite adding up here.
@rileyelf When the router is connected can you get the connection speeds and mode from the stats, this may help confirm the actual connection type.
14-07-2017 11:24 AM
14-07-2017 11:25 AM
The line is testing as fibre.
Sync Status | Out Of Sync |
Downstream Speed | 80.0 Mbps |
Upstream Speed | 20.0 Mbps |
If your router advises it's in sync at ADSL, it's likely to be a cross jumpering issue.
I'd recommend reporting this to us at http://faults.plus.net so that we can arrange an engineer.
Let us know once you've done that.
14-07-2017 11:31 AM - edited 14-07-2017 11:33 AM
I'd hazard a guess that BT hasn't completed the work at the cabinet correctly. Needs a staff member to verify with BTOR.
Sorry @Gandalf posts overlapped.
14-07-2017 11:35 AM
