Upgraded to Fibre Unlimited Extra but speed isn't any different
craig76
Hi all,
I upgraded to fibre unlimited extra yesterday, but I'm still only getting the speed I've always had.....38mb. Estimated line speed is 80mb, has anyone any advice on how to fix this?
Thanks in advance.
etdsaunders
Fixes: 7
Re: Upgraded to Fibre Unlimited Extra but speed isn't any different
Hello Craig,
Welcome to the forums, I see you've upgraded can you please login https://portal.plus.net/my.html?action=data_transfer_speed and tell us what it says for current line speed?
If it show's higher than 40mb, you may need to just disconnect in the router and reconnect for speeds to take effect
Raspberry Pi enthusiast!
If you Like it, give it a Thumbs Up
MattyC
Champion
Fixes: 46
Hi Craig,
Looks like you were provisioned on the wrong product, but my colleague placed an order to correct this earlier. Are you ok to let me know if there's still issues tomorrow?
Matty
