Upgraded to Fibre Extra, but still on Standard Speed
AndyDane
I upgraded to Fibre Extra at the start of the week, and had the completion email. But my speed hasn't increased and my modem is synced at 39.99 / 9.99.
The Plus.net profile shows that it's been set to 80, and I should be getting 52 - 78, and the DSL estimator shows these speeds are achievable. But, when I run the bt wholesale speed checker, it's saying the max line speed is 38.
I have raised a ticket a couple of days ago, but have had no response, so no idea whether this is just a waiting game, or if there is an actual fault?
8 REPLIES 8
Fixes: 1,483
Re: Upgraded to Fibre Extra, but still on Standard Speed
have you done a disconnect / connect in the router since the change occured?
AndyDane
Yeah a couple of times, restarted it for good measure too
AndyDane
Stats below:
Phone exchange:NORWICH NORTH
Estimated line speed:74Mb (This may vary between 52Mb and 74Mb) - Checked on 2018-03-06 11:55:45
Current line speed:80 Mb
Download speedachieved during the test was - 30.12 Mbps
 For your connection, the acceptable range of speedsis 20 Mbps-38.71 Mbps .
 Additional Information:
 IP Profile for your line is - 38.71 Mbps
Downstream: 39.99 Mbps
Upstream: 9.995 Mbps
High Low High Low
VDSL Range A (Clean) 74.5 52.7 20 16.3 44.9 Available -- --
VDSL Range B (Impacted) 65.2 40 20 11 35 Available --
rongtw
Fixes: 12
Hi , IP Profile for your line is - 38.71 Mbps looks like one the staff needs to bump you profile a bit Thumbs_Up
Fixes: 396
I don't think so.  The line is only synching at 39Mb, the upgrade hasn't happened yet, despite the email saying but has!
Fixes: 1,600
Hi there. Sorry to hear your speeds haven't increased following your upgrade to Fibre Extra.
It doesn't look like we've placed the modify order to 80/20 with our suppliers. Sad
I'm placing it now and I'll update your fault ticket shortly. Apologies for the inconvenience caused.
AndyDane
Oops Smiley
No real inconvenience caused other than wondering what was up.
Thanks for looking into it for me
Fixes: 1,600
No problems at all. Let us know how your speeds look next week. Smiley
