Upgraded package (Fibre Unlimited to Fibre Unlimited Extra) yet no difference in speeds.
ErTnEc
Re: Upgraded package (Fibre Unlimited to Fibre Unlimited Extra) yet no difference in speeds.
So, stats nearly a week after the SNR delta was tweaked to drop it to 3dB:
  ---------------------- ATU-R Info (hw: annex A, f/w: annex A/B/C) -----------
   Running Mode            :      17A       State                : SHOWTIME
   DS Actual Rate          : 57810000 bps   US Actual Rate       : 19999000 bps
   DS Attainable Rate      : 65973720 bps   US Attainable Rate   : 22582000 bps
   DS Path Mode            :  Interleave    US Path Mode         :        Fast
   DS Interleave Depth     :      842       US Interleave Depth  :        1
   NE Current Attenuation  :       17 dB    Cur SNR Margin       :        3  dB
   DS actual PSD           :     7. 2 dB    US actual PSD        :    12. 8  dB
   NE CRC Count            :       93       FE CRC Count         :   390206
   NE ES Count             :       24       FE  ES Count         :   352118
   Xdsl Reset Times        :        0       Xdsl Link  Times     :        1
   ITU Version[0]          : fe004452       ITU Version[1]       : 41590000
   VDSL Firmware Version   : 05-07-06-0D-01-07   [with Vectoring support]
   Power Management Mode   : DSL_G997_PMS_L0
   Test Mode               : DISABLE
  -------------------------------- ATU-C Info ---------------------------------
   Far Current Attenuation :       21 dB    Far SNR Margin       :        7  dB
   CO ITU Version[0]       : b5004244       CO ITU Version[1]    : 434da48c
   DSLAM CHIPSET VENDOR    : < BDCM >
                  Near End        Far End    Note
 Trellis      :      1               1
 Bitswap      :      1               1
 ReTxEnable   :      0               0
 VirtualNoise :      0               0
 20BitSupport :      0               0
 LatencyPath  :      0               0
 LOS          :      0               0
 LOF          :      0               0
 LPR          :      0               0
 LOM          :      0               0
 SosSuccess   :      0               0
 NCD          :      0               0
 LCD          :      0               0
 FECS         :   119329302            1009423 (seconds)
 ES           :     24            352118 (seconds)
 SES          :      0              42 (seconds)
 LOSS         :      0               0 (seconds)
 UAS          :     30            24691 (seconds)
 HECError     :      0               0
 CRC          :     93            390206
 RsCorrection :      0               0
 INP          :      0              15 (symbols)
 InterleaveDelay :      0             800 (1/100 ms)
 NFEC         :    254              85
 RFEC         :     16              16
 LSYMB        :   5374            17889
 INTLVBLOCK   :    127              85
 AELEM        :      0            ----
The modem has been connected continuously since then, and I've had no alerts about it reconnecting the session.  CRC errors seem 'OK' for a week?  There was some fluctuations with SNR on the 17th, not really sure what was going on there, as it was during the day so I'd assume it wasn't DLM?  Speeds seem fairly stable still, where it's holding around 49Mbps down, and bufferbloat values are still holding steady with no discernable latency spikes when hammering either downloads or uploads.
I'm unsure whether or not to reset the SNR delta back to default, and see if the line profile adjusts to keep the 3dB margin?  Is that likely or would it just stick & hang around at 6dB still...
Beyhive
Fixes: 43
Hi @ErTnEc,
We're glad to hear that things are holding up. I would not personally advise on changing anything since the speeds are consistent and the line being stable from our end with no disconnections in the past 7 days.
 Faris
ErTnEc
So it's been about 6 weeks(ish) since I last updated.  And things are looking pretty good.
My line is no longer interleaved, and I've noticed a huge improvement in both response times & latency.  My line was (at that point).  Attainable rate remained at 60mbps, but sync rate jumped up t0 the same attainable rate (60mbps) from what it was syncing at due to interleaving (52mbps).  My IP Profile was set at 58.91Mbps, so pretty good.  For reference, SNR delta was set to default at this point.
On Friday, I've adjusted the SNR delta to -25 (which shows as an SNR margin of 3dB), this has now caused both attainable and sync speeds to jump to around 70Mbps, which is nice.  IP Profile is still currently set at 58.91Mbps, but will leave it & let this adjust.  These are my current stats since adjusting the delta on Friday.  I'm pretty pleased with the low level of CRC errors compared to when interleaving was active on the line!
   DS Actual Rate          : 70094000 bps   US Actual Rate       : 19999000 bps
   DS Attainable Rate      : 69889012 bps   US Attainable Rate   : 22507000 bps
   DS Path Mode            :        Fast    US Path Mode         :        Fast
   DS Interleave Depth     :        1       US Interleave Depth  :        1
   DS actual PSD           :     7. 3 dB    US actual PSD        :    12. 9  dB
   NE CRC Count            :     2474       FE CRC Count         :   408269
   NE ES Count             :     1562       FE  ES Count         :   368631
   Xdsl Reset Times        :        0       Xdsl Link  Times     :        4
   Test Mode               : DISABLE
   Far Current Attenuation :       21 dB    Far SNR Margin       :        6  dB
 Trellis      :      1               1
 Bitswap      :      1               1
 ReTxEnable   :      1               1
 VirtualNoise :      0               0
 20BitSupport :      0               0
 LatencyPath  :      0               0
 LOS          :      2               0
 LOF          :      0               0
 LPR          :      0               0
 LOM          :      0               0
 SosSuccess   :      0               0
 NCD          :      0               0
 LCD          :      0               0
 FECS         :      0            100786 (seconds)
 ES           :   1562            368631 (seconds)
 SES          :    104              44 (seconds)
 UAS          :     31            24794 (seconds)
 HECError     :      0               0
 CRC          :   2474            408269
 RsCorrection :      0               0
 INP          :    230             220 (symbols)
 InterleaveDelay :      0              20 (1/100 ms)
 NFEC         :     32              32
 RFEC         :     16              16
 LSYMB        :     16              16
 INTLVBLOCK   :     32              32
 AELEM        :      0            ----
In regards to speeds, while my line was syncing at 60Mbps for 4+ weeks, I did notice transfers were still only hitting around 54Mbps at max, and given I'm on a static IP address, is this something which still needs to be updated on your side as previously mentioned?
MatthewWheeler
Fixes: 405
Thanks for getting back to us @ErTnEc
Glad to hear that you've seen an increase.
With regards to the profile on our end, it's currently set at 58.6mpbs which will be due to the IP profile still being low.
Once the IP profile increases the profile on our end should also increase
 Matthew Wheeler
