Upgraded line but not able to get internet connection
FIXED- Subscribe to RSS Feed
- Upgraded line but not able to get internet connect...
09-03-2021 12:01 PM
I've had a line upgrade and have received a new router but after a week I still have to internet connection.
I've reset router a number of times but it still has the username setup@plusdsl.net.
I've had no communication from plusnet since confirmation the router is being posted.
Should I still be waiting for anything to be configured or do I have an issue?
Fixed! Go to the fix.
09-03-2021 12:39 PM
Thanks a lot for reaching out and I'd also like to apologise for the issues you're having in getting your FTTC connection up and running.
I've run a test on my end and can see that your router appears to be in Setup mode, which means it needs to be configured to your account in order to work.
Please log into your Plusnet Hub One manager by entering 192.168.1.254 into the URL bar on your browser. Navigate to Advanced Settings, and then select "broadband" on the sub-menu.
Enter your account username, followed by @plusdsl.net, and your account password in order to authenticate.
Feel free to reach out if you have any further issues.
-Adam
Re: Upgraded line but not able to get internet connection
09-03-2021 12:41 PM - edited 09-03-2021 12:42 PM
09-03-2021 12:52 PM
Hi Tom,
thanks for the quick response.
Actioned what you suggested above and all seems working now.
Many thanks.
Steve
09-03-2021 12:55 PM
Thanks @jab1
Yep - apparently router stuck in setup mode so forcing the username/password change worked.
What I didn't appreciate, but is logical, is I had to disconnect before I could edit the details.
03-04-2021 12:06 PM
apologies @adam945 for calling you Tom!! no idea what happened there!
Steve.
03-04-2021 12:35 PM
This topic has been moved from ADSL Broadband to Fibre Broadband.
Customer and Forum Moderator. Windows 10 Firefox 100.0.1 (64-bit (64-bit)
