Upgraded from Unlimited Fibre to Unlimited Fibre Extra SPEED almost halved! 21Mbps out of 54.6Mbps
FIXED- Subscribe to RSS Feed
- Upgraded from Unlimited Fibre to Unlimited Fibre E...
- « Previous
- Next »
Re: Upgraded from Unlimited Fibre to Unlimited Fibre Extra SPEED almost halved! 21Mbps out of 54.6
27-10-2020 8:54 AM
SOrry to say you were wrong. They changed my profile which increased my speed to 33 mbps...
27-10-2020 9:50 AM - edited 27-10-2020 9:51 AM
PlusNet have no direct control over the BT profile, it is set directly by BT Openreach according to the speed at which you synchronise with the DSLAM. What PlusNet can do, is to request BT OR to 'reset' the DSLAM. Sounds like that what was done in this case. However, if the speed reduction was caused by errors on the line which are still present, then the DSLAM will again reduce the speed and Profile over time.
27-10-2020 9:56 AM
@cochin007 Actually you are wrong, as @MisterW said your speed was limited by the BT Wholesale IP profile which is not under Plusnet's control. They have done nothing to increase your speed. If you try the BT speed test again I expect you will find that the BT profile which automatically tracks your sync speed has been updated but not by Plusnet.🙂
27-10-2020 11:24 AM
Hi ,
i raised this issue with support which forwared it to their backend team and they did something. Only thing BT engineer does is dlm reset which they tried before...and the guy who came said back end has changed something. BT openreach cannot change profile .They just do basic trouble shooting as far as i know
27-10-2020 12:41 PM
The dlm reset was done multiple times and openreach person doesnt do anything as far as i know other than dlm reset and checking for issue...
The day i switched to plusnet my speed decreased. and it looks like there are things other than dlm reset..
Current Rate(kbps) | 7132 | 30472 |
Max Rate(kbps) | 7132 | 36423 |
See my current rate for last 3 weeks...
It will increase over time but never fall back to 20 mbps.
But it needs some change which plus net requested to some one in the backend...
I have done dlm reset multiple times which made no effect... Either its do with the modem of Plusnet .. Now i use tp-link or some change somewhere else... Not sure.. Just as a guidance to raise the issue with back end support by calling phone.. The agent said they wont directly attend calls... But after a week something changed...Now issue is with Static IP...lol
- « Previous
- Next »
