Upgraded from Unlimited Fibre to Unlimited Fibre Extra SPEED almost halved! 21Mbps out of 54.6Mbps
FIXED- Subscribe to RSS Feed
- Re: Upgraded from Unlimited Fibre to Unlimited Fib...
Re: Upgraded from Unlimited Fibre to Unlimited Fibre Extra SPEED almost halved! 21Mbps out of 54.6
21-09-2020 2:20 PM
Yes, as I thought, your upgrade hasn't happened. You're synching at the maximum for a 40/10 (unlimitdd fibre) product.
on 21-09-2020 2:44 PM - last edited on 21-09-2020 8:55 PM by Strat
@MisterW, thanks for that. Now to find someone who will push that upgrade through! Anyone here on the staff care to?
Moderator's note by Dick (Strat): Full quote of preceding post removed as per Forum rules.
21-09-2020 7:44 PM
I'm the OP here and the guy with HH5 running openwrt.
Which numbers are you looking at in the openwrt output?
72 hours after the upgrade went through was getting
"data_rate_down_s": "64.288 Mb"
"max_data_rate_down_s": "64.625 Mb"
now > 7 days later:
"data_rate_down_s": "71.835 Mb"
"max_data_rate_down_s": "75.435 Mb"
Got a call from plusnet in response to a support ticket I raised on the above opening question "Is it normal for some settling time after upgrade and how long?" and they tell me my line is "Training" which lasts 10 days and my line speed is as experienced still subject to fluctuation.
Testing on the router itself, the speed tests are still swinging between 20 and 36 Mbps which it about the same seen from a wifi connected laptop
Used the same download source for all tests (http://speedtest-download-btwholesale.akamaized.net/PT/1000MB.bin)
root@LEDE:~# /etc/init.d/dsl_control status
ATU-C Vendor ID: Broadcom 164.161
ATU-C System Vendor ID: Broadcom
Chipset: Lantiq-VRX200
Firmware Version: 5.7.9.9.0.6
API Version: 4.17.18.6
XTSE Capabilities: 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x2
Annex: B
Line Mode: G.993.2 (VDSL2)
Profile: 17a
Line State: UP [0x801: showtime_tc_sync]
Forward Error Correction Seconds (FECS): Near: 0 / Far: 717
Errored seconds (ES): Near: 1 / Far: 211
Severely Errored Seconds (SES): Near: 0 / Far: 0
Loss of Signal Seconds (LOSS): Near: 4 / Far: 0
Unavailable Seconds (UAS): Near: 115 / Far: 115
Header Error Code Errors (HEC): Near: 0 / Far: 0
Non Pre-emtive CRC errors (CRC_P): Near: 0 / Far: 0
Pre-emtive CRC errors (CRCP_P): Near: 0 / Far: 0
Power Management Mode: L0 - Synchronized
Latency [Interleave Delay]: 0.13 ms [Fast] 0.0 ms [Fast]
Data Rate: Down: 71.835 Mb/s / Up: 19.766 Mb/s
Line Attenuation (LATN): Down: 14.8 dB / Up: 16.8 dB
Signal Attenuation (SATN): Down: 14.8 dB / Up: 16.5 dB
Noise Margin (SNR): Down: 3.5 dB / Up: 5.9 dB
Aggregate Transmit Power (ACTATP): Down: 6.5 dB / Up: 13.8 dB
Max. Attainable Data Rate (ATTNDR): Down: 75.419 Mb/s / Up: 19.758 Mb/s
Line Uptime Seconds: 56693
Line Uptime: 15h 44m 53s
22-09-2020 10:39 AM - edited 22-09-2020 10:52 AM
@tol it's these numbers in the output that are significant
They look fine.
Are you doing the speed tests using a wired connection ?
You need to run the BT wholesale speedtest from here https://speedtest.btwholesale.com using a wired connection , and then preferably go on to run the Additional diagnostic test
23-09-2020 12:22 AM
Wired connection or wifi, makes no difference the speed test is always less than it was before the upgrade started.
This is just now over ethernet directly plugged into the router:
This test was not conclusive and further testing is required. This might be useful for your Broadband Service Provider to investigate the fault. Note:An error occurred while trying to retrieve additional details regarding your service. As a result we are unable to determine if the speed you received during the upstream test is acceptable for you service. Please re-run the test if you require this additional information.
Annex: B
Profile: 17a
Forward Error Correction Seconds (FECS): Near: 0 / Far: 2320
Errored seconds (ES): Near: 3 / Far: 238
Severely Errored Seconds (SES): Near: 1 / Far: 0
Signal Attenuation (SATN): Down: 14.8 dB / Up: 16.6 dB
Noise Margin (SNR): Down: 3.5 dB / Up: 5.8 dB
Max. Attainable Data Rate (ATTNDR): Down: 75.188 Mb/s / Up: 19.766 Mb/s
Line Uptime Seconds: 159840
Line Uptime: 1d 20h 24m 0s
23-09-2020 7:24 AM
@tol I notice in your initial post that the "current line speed ' is set to 21Mb . Normally that will have no effect UNLESS you have a static IP . Is that the case ?
23-09-2020 9:44 AM - edited 23-09-2020 9:45 AM
@MisterW Yes I do have a static IP. What effect does this have?
The Broadband page in members-centre still says:
Your broadband service
- Product: Unlimited Fibre Extra
- Estimated Download Range: 60 - 72Mbps
- Estimated Upload Range: 17 - 18Mbps
- Minimum Guaranteed Speed: 54.6Mbps
- Current Line Speed (Download): 21Mbps
23-09-2020 11:04 AM - edited 23-09-2020 11:09 AM
@tol the 'current line speed' is a legacy profile that PlusNet maintain which historically was used to control thoughput. It SHOULD follow any changes in the BT wholesale IP profile but occasionally it gets stuck. Sometimes when changing products it can get reverted to the maximum value for ADSL ( 21Mb ) which looks to be the case in your situation.
Now for most of the accounts this no longer has any affect and doesn't matter if it's incorrect. However , any accounts using a static IP are routed differently across the PlsuNet network ( they go via L2TP ) and so the current line speed DOES limit the thoughput. Many of the first line CSC support personnel are not aware of this and so it is not considered when looking at speed problems. The PlusNet help team are trying to ensure that the CSC are aware of the problem and do consider it. Since the current line speed setting is a PlusNet controlled parameter it can be simply reset without any BT involvement and if this is the cause of the problem can be quickly rectified.
In the absence of any of the Help team picking this up , I suggest that you raise a fault at faults.plus.net ensuring that you mention that the current line speed is incorrectly set at 21Mb and that you have a static IP so it WILL have an effect.
28-09-2020 8:07 PM
Exactly 2 weeks after the upgrade went live, Plusnet have finally looked in to the advice provided here by @MisterW and switched my provision from ADSL+ to 80/20 Fibre.
1 router restart later and I'm looking at speed test results a lot closer to what I am paying for
- Current Line Speed (Download): 78Mbps
29-09-2020 7:17 AM
@tol Good to see it got sorted
29-09-2020 6:22 PM
@tol You have been on VDSL2 (80/20 FTTC) ever since the upgrade, the problem was the incorrect Plusnet profile or current line speed which restricts the speed if you have a static IP. Unfortunately support did not spot this, and there has been an unnecessary delay but you have got there in the end.😊
30-09-2020 1:46 PM
30-09-2020 1:51 PM
As detailed above, check the Broadband page in the member centre portal and see what it say fro Current Line speed
30-09-2020 6:42 PM
It says in Bt wholesale test
Download speed achieved during the test was 18.10 Mbps For your connection, the acceptable range of speeds is 20-20.73 Mbps Your DSL Connection Rate: 0 Mbps(DOWN-STREAM),0 Mbps(UP-STREAM) For your connection, the maximum achievable download speed is 20.73 Mbps IP Profile for your line is 20.73 Mbp
Any advice?
02-10-2020 11:26 AM
@cochin007 your problem is NOT caused by an error in the PlusNet profile
Your BT IP profile is showing IP Profile for your line is 20.73 Mbp
