Upgraded from Unlimited Fiber to Unlimited Fiber Extra - No change!
- Upgraded from Unlimited Fiber to Unlimited Fiber E...
- « Previous
- 1
- 2
- Next »
Re: Upgraded from Unlimited Fiber to Unlimited Fiber Extra - No change!
20-04-2019 9:31 PM
Cheers, it indicates that you're disconnected from the internet rather than being blocked in any way.
As Our logs still show you as connected it would be best to try powering your router off for a few minutes then back on and you should reconnect.
If it continues to be a problem beyond that it would be best to report another fault as it looks like you've closed the previously raised one from earlier.
20-04-2019 9:38 PM
I didn't mean to close the case, the view and close buttons are too close together on the mobile website and there is no confirmation.
Poor.
How do I raise the fact my login details are no longer valid?
20-04-2019 9:44 PM
Your login details haven't changed or been affected so I'm not sure what's causing that at this stage. If you go to http://faults.plus.net have you made sure you've entered the username without the @plusdsl.net suffix that you will have entered into the connection settings?
20-04-2019 9:58 PM
If I try to log a fault I get the screen attached.
21-04-2019 9:20 AM
Apologies it looks like the incorrectly closed ticket's become stuck. The fault's still open though so I've transferred it to this ticket. Can you pop some availability on the ticket for me and I'll get a visit booked.
21-04-2019 8:09 PM
21-04-2019 8:17 PM
- « Previous
- 1
- 2
- Next »
