Upgraded fibre to 76mb, still slow speeds!
Hi Plusnet,
I recently upgraded my service from the 38mb fibre to the 76mb fibre, however, I'm experiencing slow download speeds of around 25mb, similar to that of my old service. My upload speed has increased, so I can tell that the new service has been enabled on my account. I have ran the BT speed tests and have posted the results below. I've also noticed that my line seems to slow down more in the evening to a measly 2-5mb.
3 REPLIES 3
Re: Upgraded fibre to 76mb, still slow speeds!
Attempted the ' further diagnostics' via BT speed test, getting this after I enter the username into my router. Any help anybody?
Fixes: 62
If those tests are wired and are similar to before you upgraded it would indicate a problem as you are in sync at a much higher speed
Have you tried reporting a speed fault at https://faults.plus.net
Although this may indicate part of the problem https://portal.plus.net/my.html?action=data_transfer_speed
Fixes: 391
Sorry to hear your speeds hasn't increased.
I can see you have a fault open regarding this and our Faults team will be in touch as soon as possible.
 Matthew Wheeler
