Upgrade to fibre
Mayfly
Upgrade to fibre
So just found out today that fibre in my area was completed on the 14th Dec 2 weeks early so rang COT as I'm on deal with PN to see what it will cost me to upgrade. Got through twice at lunch time both calls answered within 3 minutes. Another good deal was offered and appointment for install morning of 15th Jan.
So far so good and very pleased with the quick and efficient way it has been sorted so far. Fingers crossed it will continue to go smoothly.
Thank all so far.
Fixes: 78
Re: Upgrade to fibre
Thanks for the feedback and I'm glad to hear you're happy with the offer.
Not that there should be but if you see any issues on the 15th just drop us a reply back here please.
 Adam Walker
Mayfly
Will do Adam,
just to let you know I received the router today, 2 working days after I ordered fibre. Not bad for being posted in the Christmas maelstrom.
Mayfly
Is my fibre appointment for next Thursday confirmed please?
I may have to make arrangements for a family member to help me out if it is.
Really looking forward to faster speeds.
Mayfly
Fibre up and running, at the minute I'm getting 29.75 down and 16.5 up BIG difference from 4.5 down and .80 up
All went well and no complaints the only thing I could say if i want to be picky is there was no confirmation the appointment had been accepted tho' I believe one of the emails did say at the start that if it wasn't they would get back to but it is nice to know these things.
The engineer arrived about 10.30 and was away by 10.50.
Is there a 'settling period' for fibre?
Thanks all concerned I'm a happy bunny.
sjptd
Is there a 'settling period' for fibre?  Yes.  It starts on maximum speed it thinks it might get away with.  DLM then monitors the line for errors over a couple of days or so.  After that, it decides whether the line is stable at the flat out rate, or whether it should be slowed down by (a) use of higher target snr resulting in greater stability but lower sync speeds, and/or (b) introduction of interleaving which will reduce the number of uncorrectable errors, but lower throughput and increase latency (ping times).
If there are extreme issues, DLM will intervene even before the couple of days are up.  DLM will continue to monitor the line for ever.
Fixes: 5
I'm really pleased that everything went well and that you've had such a big increase in speeds.
We're changing the provisioning systems soon, so hopefully communication will improve re the appointments.
 Tony T
